[Software Update] iOS 16.1.2
Jirachi
is POSB app same as DBS? If yes, before and after upgrade I had no issue with Face ID.
Yes. Essentially the same.
There is no problem with iOS 16.0. There were problems with iOS 16.1 starting from some beta onwards till now.
I am stuck with this problem since some beta in iOS 16.1
tohchr
I did not go thru beta. From 16.0.3 straight to 16.1, I had no issue with Face ID. Did u try uninstalling and install again? Then setup your Face ID again?
Scuderia
Mine DBS app faceid was working fine yesterday, after update not working.
ragnarok95
Senior Moderator
Senior Moderator
Log in with normal password then re-enable face id again and try?
