Was it a ported number? Give it a few days. I usually have issues receiving calls and sms for the first few days after porting as the other telcos update where my phone number ismy spouse just signed up m1 5g
Yes just portedWas it a ported number? Give it a few days. I usually have issues receiving calls and sms for the first few days after porting as the other telcos update where my phone number is
Yes just ported
I am using M1 4G plan. Noticed the same issue as you on green line west side. Can’t even load my web pages. Going to port out of M1 soon.i myself also just applied m1 sim only, kns, so laggy in mrt green line. just a bit better than tpg. might hope to starhub soon
They should have RF engineers that test all these. If they can't even get things done properly, I'm speechless.
Wah, the connectivity so jialat ah?
I was about to get the 100GB Forever plan.
Quite good leh, at least for me I have no issues, can even get 1Gbps+ on M1 5G.
The pricing a bit scummy though, 5G is only "free" for 6 months, then after that it's $2 for another 6 months. Then after that $5 permanently.
M1 is far and away the cheapest 5G service, and it's honestly not bad. Better than GOMO unless you really need 5G on the NEL.
I should have remain with Starhub, M1’s 4G and 5G is less stable and slower compared to Starhub, the reason why I’m going with M1 is the data passport, other than that probably it may not be wise to go with M1.Not bad speed (from video)
I notice m1 5g coverage is not really as good as SingTel.
Travel along the East West line (land stations) the m1 5g on and off. While SingTel have coverage on all or most land mrt station.
You can always have different channels in the same spectrum lot.
For example, maybe 50MHz each to deploy inside the buildings?
What is the proper setting for iPhone14 M1 5G? Having a lot of issues after activating SA mode. Cannot receive and make calls and frequent disconnections. Is this normal?
