[Software Update] iOS 16.1.2
phrozact
Thanks for the heads up. Never knew what's the difference between the POSB and DBS banking apps, but I've now switched from the DBS to POSB app.
Fellowes
Seem like only affecting DBS banking app, they should’ve test their app during beta so upon official release 16.1, this issue should not even occur. Other banking app also no issue so it’s definitely the way DBS software team code it that break the FaceID api.
Jirachi
Yes. The DBS iBanking App likely broke the Face ID API during the same update they broke the notification badge.
netzach
saw POSB update app through app store, that's quite timely and a fast fix by POSB already, 1 week or so thereabouts.
the ***** UOB TMRW app have been crashing for weeks and the comments on the damn app store feedback about the ***** app crashing since end Sept. till now and nothing yet fixed till now ccb.
Singrish
I have no issues with UOB but the DBS app is definitely not working if you want to use FaceID.
netzach
good to hear...the UOB app crashing is like quite random knn...
loads of feedback and comments of the damn app crashing since end Sept. on the APP store.
for myself, it has been crashing since Oct. delete, re-install, set up digital token, ok and run a few days then crashing non-stop again lol.
quite TL la for me coz 1 of my paynow is tied to my UOB acct. so now I can only use POSB to paynow...
also sian coz usually time to time i do like to check on the credit card spending on the UOB mobile app to see if hit $500+/600 for the UOB one bonus interest + cashback.
POSB app is working for me tho. well & fine. :)
edm_11
Does anyone experience iphone lag when swipping off an app? Seems to be quite persistent on ios16.1
