Google Pixel 7 series
What upgrade would you most like to see on the Pixel 7 series?
  • Total voters
    140
orlengtao
You can just buy any of the available GaN USB chargers that is rated for at least 30W, although it might be wiser to get at least 65W for the added flexiblity. Baseus and Ugreen makes some of the better ones out there. If you wanna save money, there are other cheaper brands available that will do the job just as well.
Get one with safety mark approved for use in Singapore.....
Raigar
PROTECT YOUR CAMERA VISOR NOW!! It's my day 1 and I'm being extremely careful with the visor handling as I've heard about how prone to scratches it is. but I still getting it somehow.
Check out this youtuber visor, I've gotten the same scratches as him.
Loser
FYI: For those considering getting the 30W charger on its own, can consider the Pixel stand gen 2 which also comes with the 30W adapter inside.
Loser
check out this youtuber visor, I've gotten the same scratches as him.
Might be the metal stubs on your jeans pocket or your pocket is full of sand?
KeYoKe
I made the correct choice for p7 :s13:
FreddieFreako
Yes my metal plate already scratched. Bought the camera protector from taobao but too late I guess.
year2013
same.. dunno what to buy now
Same here, anyways these vouchers are valid till Mar 2023. I am trying to sell the code on Carousell at $180, if no one buy then I will buy something later!! No rush :)
Or just go for Bellroy cases and Wireless charger, etc.
nnyymm
Case-Mate TPU Screen Protector for Pixel 7
Pretty much the same as hydrogel screen protector. However, after application, this will result in slight 'crease' going across the middle of the screen. Also there are tiny bubbles which I somehow got where the crease are, looks like spec of dusts. Note that I have applied the screen protector in a well steamed bathroom. The dusts may have originated from the screen protector itself...
Conclusion is I prefer glass screen protector ☹
KeYoKe
Overpriced hydrogel :s13:
Vulpix
Moderator
Moderator
Shiny surface... No matter how careful sure will have one... Dust is everywhere...
That time I remove one of those protective stickers on wife iPhone after she used it for 2 years, got scratch underneath it. I give up protecting anything shiny. This phone I didn't even bother.
Vulpix
Moderator
Moderator
Curved screen users on copium. :(
royfrosty
Bought this for my wife. Application is weird. If I were to use the alignment tool, the camera cutout just looks off.
So went ahead to do eyeballing. It all works well, till I wanna remove a lint dust. Found it is almost difficult to remove dust as it sticks to the "stickier" side underneath. It is bad in a sense that it also attracts a not so sticky tape gum on it. I couldnt recommend it as other hydrogels are not so difficult to remove dust.
The bubbles are also at the crease area. I also would recommend tgsp instead over this.
KeYoKe
Yup correct. No matter what confirm will have unless u don't use it. Sometimes it out of the box also have le
Hence, i using the p7 instead of p7 pro... my ocd see scratches i cant :s13:
KeYoKe
Wait for ibywind to release TG for p7...
