Dual RTX 4090 build
tsteo77
I came across this awesome xeon cpu dual rtx4090 build on the internet. I posted it here for computer enthusiasts to admire.
What do you peoples think about having a dual xeon processor and dual rtx4090 gpu build ? One last thing to note is that
the rtx4090 gpu are big in size.:oops:
The specs:
2x 4090 RTX Founders Edition
2x 8280L (56/112 cores), Asus c621 Sage Dual socket motherboard
1.5 TB ram. DDR4 ECC LRDIMMs
1600W digital power supply
(Data drive) 4x VROC Raid 0 Micron 9300 Max (12.8TB each / 51.2TB array) VROC Premium key
(OS Drive) Sabrent Rocket 4 Plus (8TB). 4x Samsung 860 Pro 4TB each (16TB array)
Asus PA32UCG-K monitor, TT SFF case, MS Data Center 2022 & Ubuntu
jkohlc2
jin satki, wonder take how long to break even compared to renting computing time onine
tsteo77
The real question is will it make your music sound better?
I don't think this system good for game play or music play. The owner of this system actually
use it for Deep Learning and My Dissertation.
yusoffb01
wnder why he never use 3995WX which is faster than dual xeon
tsteo77
Perhaps it's because the tasks that the owner perform require a dual xeon processor.
Personally, i believe multi processors configuration are much better than a single one which is the case for 3995wx.
If i had that type of time/money/effort to own one.:)
Phen8210
Barely able to maintain the frames steadily
The 5900X is bottlenecking the card.
For scenes like the one below, it's fine, as there isn't much going on. The active core still has some headroom. GPU is pushed well and usage is always 95%+.
This area with a lot of destructible props is more CPU-demanding. There were instances of active cores hitting 100%, probably not showing up as much as they should due to his polling rate for the OSD being too slow (1 second). Anyway, GPU usage dropped like mad as observed.
This above scene is from the zone which starts at the 3:30 mark of the video.
This test is at 4k, so imagine at lower resolutions lol. Also, it's the same problem with cyberpunk in china town with the food stands. No point only getting good frame rate in empty scenarios :ROFLMAO: :ROFLMAO:
