POCO X4 series
Teo Ming Ern
The X4 Pro sold out on the Poco Official Store... was hoping to snare one on 11.11 but seems not likely now... probably have to look at something else...
harky
i bought the x4 pro.... faster buy because oos soon...
the phone look nt bad
Krabs.
no need to chiong because the RMN12 vanilla version is same cpu performance as snapdragon 695 and the screen also same 6.67" 120hz oled ..... sumore RMN vanilla version is very affordable
8-lane
So u're saying SD 4 Gen 1 is same performance as SD695?
Krabs.
the cpu and graphic cores are the same
clockspeed about 10% difference , means benchmark and real world less than 10% difference , probably 5-6% my estimate
if antutu is 390k , u can estimate it might be around 420k score ... the graphic still sucks for gamer
the 4gen1 is slightly slower than 695 by 5 to 8% , due to 2 big cores losing 10% clockspeed , the smaller 6 cores increase 6% clockspeed cannot recover the loss
https://nanoreview.net/en/soc-compare/qualcomm-snapdragon-695-vs-qualcomm-snapdragon-4-gen-1
8-lane
Wah all this is alien to me haha... so cheeeem haha...but I get the whole idea I guess...
harky
Do anyone had good x4 pro tempered glass To share? Bought two, isn't as good as decent brand phone..
y2k_tay
Do your x4 comes with the plastic protector? Can tear out or paste your own glass protector over it? Cos I dunno can tear out the original protector or is it a protector in the first place..... :frown:
harky
ya come with it.. tear out and replace own protector..
had to buy glass protector urself. so far cant find the one i want..
y2k_tay
Thanks for the reply, bro. Will also keep a look out for suitable screen protector.
Krabs.
if u not picky about the edges and the selfie punchhole , can just get any of the simple glass for rmn 9s 9pro , rmn 10pro , 11pro5g .... all the same 6.67" .... "poco" keyword not as easy to get search result
FuNKySoULyBrO
Anyone using X4 GT NFC bus/mrt tapping? It was working before, however, after I came back from my holiday, tapping it on mrt, the mrt gantry says invalid card etc, however, my gpay app has the tick to indicate it's pass.
Able to use gpay NFC for the retail transactions, just that for mrt, suddenly stop working without any changes...
I need to pass my Realme X50 5G to a family member, so I just got the Poco X4 GT 8GB/256GB at S$385 (12/12 promotion). The spec seems to be pretty okay for the price.
I am finishing set it up today. So far I have encountered only one issue that OOkla SpeedTest does not work. Kind of strange. It can not find the server even though I have enabled the location service.
BTW, 5G is working -- I am using Singtel SIM Only (just first three months of 100GB 5G data free, after that it is 60GB 4G data).
Finally got it working after the system upgrade. At 1m close range to my Asus RT-AX86U router.
slashiroth
Just got the x4 gt. Can't seem to be able to get the nfc to work even though it's set up and shows ready to pay. When I tap on terminal It just keeps flashing until transaction is declined. The wallet had been set to HCE as well. Any folks have any idea?
lwandyh
Any x4gt user? I see YouTube they say this phone the notification will have some relay, is it true not ah before I order from shoppee
slashiroth
My notification works fine. No delay for apps notification including banking apps and WhatsApp. But my gpay nfc just doesn't seem to work tho
No issues with notifications. It runs pretty smooth.
Interesting to know. I do not use NFC or Google Pay myself though.
slashiroth
Yeah funny thing. I've tried all sorts of method to try to get gpay nfc to work but it still doesnt. Uninstalling/factory reset/trying different cards
Gave up on it and decided to swap another phone for my NFC payment
lwandyh
Bring down to service center check?
