Sony Xperia IV
Toader
Updated my phone today with the new update, seems like the battery drain is not good?
Battery drain is normal for me (which is on the good side) did you left games / Google drive or any other battery draining applications running at background?
ranchy
Dont
Hmm I don't feel any difference... Seem normal to me...
I been using the charge till 80% under battery care.
But I felt if you charge full, somehow the phone battery seem to last even longer. The additional 20% seem to be a lot.
omelet
Thanks for the testing.
The shop already replaced me with the brand new set. Mine are HK 512gb set but the shop still willing to help me fight for the brand new set from supplier. Not sure if I can tell the shop name here but the location is far east plaza. The shop at level 2 and you can see it from outside
Hi, how is your replacement set? Does it have the same issue?
wolvie77
Trying my hands at macro with a clip on macro lens.
winner22000
In some light condition I am still able see the image I shared, the color in boxes. But this is a lot better than my 1st unit. At least now I am enjoying the Netflix show without any dark black color issue
ranchy
Just change my sim only plan for singtel to 5G.
And yes I can get 5G... Using HK set. ...
rssd21
That is surprisingly good news. Seems that singtel is getting more efficient with their 5G rollout to more smartphone brands.
Blueberrytea
Check 1 iv got volte ?
If yes when on phone call does it drop to h+ ?
Possible to use phone call and use Google maps simultaneously?
