Sony Xperia IV
darkmatt
Erm.. I am not sure if it is 5G or NSA.
I only know when I'm using the 4g line,I never see before 5g on the phone.
Only getting the 5g line,then I can see it.
NSA is just 4G+++++++++++++++
SA is the true 5G.
important difference
Toader
What's new in android 13?
Those who updated do help check does 125mm improved more about sharpness?
ranchy
Thanks for sharing. Yes they should have a change updates to share.
Not yet test the camera at 125mm.
Felt that the animations transition not as fluid.. example closing of WhatsApp. Can feel a slight lag sometimes..
Disclaimer, I am not using the 120hz. Will test out that settings, maybe it will be better.
mortpenguin
Same here, just updated yesterday and the lag when closing apps is very obvious, the animation is not smooth - the app will appear as a smaller window for half a second before disappearing. I tried both normal and 120hz and the problem remains.
Battery life looks a bit suspicious as well. Will continue to monitor.
rssd21
our phones have SA.. the telcos dont support it..
This is true. My sub $500 xiaomi phone can connect to 5G SA network, what makes it more difficult for a sub $2000 phone to do that. Maybe sony should pay the telcos to do their job properly, just like those incentives from some phone makers.
