Cannot be, helio g99 is 4g.malaysia one have 5G
True but buying the local version is pretty expensive relatively speaking... I think buying the China version is still bang for buck... cos you can always tap on your phone's data plan if you take the tablet out...Another difference, M10 gen 3 sold in Singapore has lte. Big advantage when one can use data sim from as low as $5 a month
Is there a M10 gen 3? Can't find it in Lazada, shopee. Can share here?Another difference, M10 gen 3 sold in Singapore has lte. Big advantage when one can use data sim from as low as $5 a month
Got, check out Harvey Norman... I played with the display set at Jurong Point's Harvey Norman... that uses a Helio G99 chip set... not the SD680 for the Xiaoxin Pad 2022 (China version)...Is there a M10 gen 3? Can't find it in Lazada, shopee. Can share here?
I tried out... 4 GB RAM is too little... UI is not smooth and stutters quite a bit... the 64 GB storage is really small... overall for the price asked for - not worth it... even the LTE slot isn't worth it... I rather have a UI UX that is smooth and fluid... so minimum 6 GB RAM...https://shopee.sg/product/241017226/14188437586
Physical set available at some harvey norman / courts. Recommend to try it out first
Redmi 6gb but no LTEI tried out... 4 GB RAM is too little... UI is not smooth and stutters quite a bit... the 64 GB storage is really small... overall for the price asked for - not worth it... even the LTE slot isn't worth it... I rather have a UI UX that is smooth and fluid... so minimum 6 GB RAM...
Haven't tried but no microSD card slot is a deal breaker for me...Redmi 6gb but no LTE
Redmi Tablet has mSD slot. It is Xiaomi Pad 5 that don't have mSD slot.Haven't tried but no microSD card slot is a deal breaker for me...
Oh I must be confused... thanks for pointing out...Redmi Tablet has mSD slot. It is Xiaomi Pad 5 that don't have mSD slot.
That lenovo seems very similar to oppo pad air in specsWow! $369 is pretty high price for what is essentially a basic tablet?
Your MiPad 4 Plus is a 10.1" tablet, while this is a 10.61" tablet - that's where the extra size comes in...
I'm comparing this Redmi Pad to a Lenovo Xiaoxin Pad 2022 or the global equivalent of the Lenovo Tab M10 3rd Gen - identical specs save for the Redmi have 90 Hz screen, and the Helios G99 vs the Snapdragon 680... oh, the Redmi has faster storage with UFS 2.2 while the Lenovo is eMCP...
Good option too... but price difference big?Anyone getting the s6 lite instead? At $400 with snapdragon and s pen, seems like a good buy.
Sometimes tab s6 lite cost $350 on Amazon.Good option too... but price difference big?
small correction, variant of redmi pad sold in singapore is 6gb ram 128gb storage versionSometimes tab s6 lite cost $350 on Amazon.
S6 lite - snapdragon, 4gb 64gb storage and s pen
Redmi pad - 6gb 64gb storage.
Just not sure performance any difference
Not sure if can get the S6 Lite for so cheap but maybe Black Monday can see see...250 can consider. Otherwise take the mi pad 5 or even the tab s7
