u compare the price already?Guys, anyone one used AIRALO app?
How this Jetpac is better deal than Airalo which provides eSIM data plan.
So far for all my trips, I always use Airalo..on an average SGD 18 for 10GB data (30 days validity)u compare the price already?
I think price wise jetpac seems better cos it cover 50countries..but depends on your usage bah..So far for all my trips, I always use Airalo..on an average SGD 18 for 10GB data (30 days validity)
Not sure how Jetpac is better choice - just want to understand more!
I think the inconvenience is you need to have internet access (e.g. hotel wifi) to buy the plan. Not sure if they will be able to generate the profile for you to install on your phone immediately, or need to wait.I think price wise jetpac seems better cos it cover 50countries..but depends on your usage bah..
anyone know if this jetpac can be activated when overseas? (eg, if my free simba 1gb didnt work and this $10 3gb will comes in handy)
CL is probably reselling from other eSIM providers for JetPack. That is why they have different eSIM profiles in the same package, to cover the 50+ destinations.funny is that it's showing as singtel..I thot circles life is M1?
Can you use the data when on SingTel?funny is that it's showing as singtel..I thot circles life is M1?
Ya. It's showing Singtel as network and network provider is 1010 / CSL 52.0CL is probably reselling from other eSIM providers for JetPack. That is why they have different eSIM profiles in the same package, to cover the 50+ destinations.
If you're on iPhone, maybe you can see what carrier profile they're holding on when you're latched on SingTel.
Settings -> General -> About -> Network Provider (for the eSIM). It's very unlikely to be M1 Singapore.
Didn't try cos still in sgCan you use the data when on SingTel?
There is a R logo beside the ST signal strength on my phone. So I believe CL partnered with some other foreign telco (looks like its 1010 by CSL Mobile as per ekardo's post) to provide this Jetpac service. And when in SG, its roaming on ST network. Did not try to use the data on ST though.Can you use the data when on SingTel?
Oh I mean it's 20GB for first bill cycle, I thought can spare a bit and see if it's usable. But np.Didn't try cos still in sg
Means you're a roaming customer and the origin carrier is CSL HK.Ya. It's showing Singtel as network and network provider is 1010 / CSL 52.0
Didn't wanna waste for my 3gb plan. I think not even enough for my upcoming tripsOh I mean it's 20GB for first bill cycle, I thought can spare a bit and see if it's usable. But np.
just tried. cantCan you use the data when on SingTel?
alamak...then overseas can use or not sia ?just tried. cant
should be can lah, why would they launch something that doesn't work. Will know this weekendalamak...then overseas can use or not sia ?
i will know on thurs...bkk..should be can lah, why would they launch something that doesn't work. Will know this weekend
