georgie
anyone on senior plan face bad signal? my dad one just changed and only 1-2 bar signal at NUH
sevensomerset
just pop in sim card into iphone14pro
eh, why show LTE? thought it’s a temporary terminology for 4G?
btw did a side by side speedtest with android phone, same server,
ip14pro achieved 95Mbps down, 0.83Mbps up
realme3gt achieved 3.3Mbps down, 5.8Mbps up:s22:
Modd-36
Iphone 14 pro and Realme 3GT? 🫣
Supported antenna bands of Realme so little compared to iphone. Maybe use samsung ultra to compare better mah.
Jurong640
It's not plan based. The signal at basement of NUH medical centre is bad, near Crave Nasi lemak. I've feedback to them before and will need time to rectify the bad signal.
georgie
looks like NUH problem. was at level 17. 1-2 bar.
sevensomerset
Realme antenna bands so little meh?
RealmeGT3 NEO
4G: LTE TDD:B38/B39/B40/B41(2496-2690MHz)
4G: LTE FDD:B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B18/B19/B20/B26/B28/B66
Iphone 14 Pro Max
FDD-LTE (Bands 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 25, 26, 28, 30, 32, 66)
TD-LTE (Bands 34, 38, 39, 40, 41, 42, 46, 48, 53)
exterminazn
Hi expert just change to simba
but I don’t see the tether option (personal hotspot) in my phone….
how to enable?
hobolux1
Anyone can advise if the Volte will use up a lot of battery for iphone? Thinking of changing but worried about the battery life.
and whether the data/call connection in Seng kang is fine?
gapboy
just a small battery increase not much significant if you charge your phone every few hrs a day, also depends what kind of phone you have
