PC unable to turn ON
loserqueen
Need Help, Unable to turn on my PC, off/ON no function. I try and open reinsert the ram, still the same.
but press behind button ( forces open / close button) fan will move awhile.
CPU : i3-9100 CPU @ 3.60GHz
GPU :N.A
Motherboard: ASRock H310CM-HDV
Ram : 02 x 8GB RAM
Storage: 240GB SSD
Storage : 1TB HDD
LiLAsN
GPU :N.A
Ram : 02 x 8GB RAM
Storage: 240GB SSD
Storage : 1TB HDD
Unplug and replug your power cables on the motherboard and PSU side. Sometimes, there might be an accidental loose connection on the wire like on the CPU power cable on the top left of the motherboard which sends power to the CPU.
tsteo77
GPU :N.A
Ram : 02 x 8GB RAM
Storage: 240GB SSD
Storage : 1TB HDD
Looking at your computer specification, it's seem quite old. What PSU are you using ? It could be the age of PSU that
is dying. Bring to a computer to check and replace any ageing parts that might be dying.
loserqueen
ok, will try again, but behind got 1 button can press, got light and fan will move,
aLvInCbH
Had a similar problem with my 11 yo computer last month. Power on, fan will spin a while and then stop totally. Checked the motherboard. All the components look ok. Replaced the PSU and everything works again.
loserqueen
Ok. Alr buy PSU, will change on Sunday
unculturedf
Maybe bring down to a shop to diagnose?
At this rate you may end up doing an overhaul :s22:
aLvInCbH
My 11yo computer is still running perfectly fine after replacing the PSU. The old PSU did power on and spin for a while. I don't study electronics, so I don't know if 1 component of PSU spoil will cause the whole PSU to not turn on at all or not. I dust and reapply thermal paste every few years (did this before replacing the PSU).
Koenig168
This should be the case. You do want the protection features to kick in and stop the PSU from working otherwise you risk taking out the rest of the PC.
TrEaSuRe
My old pc also had the same problem as TS. Press power button, cpu fan use spin a while and it stop. Mine is the mobo issue.
Daty41
Do the easy stuff first, after chexking everything plug in nicely.... Test on 1 stick of ram, if fail swap ram and test....or unplug anything that can cause a short (fans / HDs)... But not the CPU fan... Maybe swap the fan is all. Unplug and still cannot on.... After that is the CPU or MB liao...
Bui Kia
So many possibility ..might be mobo or ram
so save all the trouble and time ............
conculsion : Time to built a new desktop pc :s42:
less than 1k can built much better than your current old pc
