Sony Xperia IV
rssd21
How to see?
Access the hidden menu, think it probably works on all android phones.
*#*#4636#*#* – [Phone Information.] [Battery Information.] [Usage Statistics.] [Wi-Fi Information.].
Phone information will show if the network:
4G - LTE
5G - NR SA or NR NSA
mortpenguin
Same here, just updated yesterday and the lag when closing apps is very obvious, the animation is not smooth - the app will appear as a smaller window for half a second before disappearing. I tried both normal and 120hz and the problem remains.
Battery life looks a bit suspicious as well. Will continue to monitor.
Is no one else seeing the lag on their phones??
mortpenguin
I did not see lag . I went developer option set all animation transition to off .
Right.. but not excusable if the stock UI is showing lag.
Another bug I'm seeing is that after the update, for some reason Whatsapp isn't able to access the camera's gallery folder to share photos - the folder doesn't show up. I have to manually access the gallery and share the photo to Whatsapp from there.
ApexMan
aiyor Sony failing back again
ranchy
Oh.. I have the same issue. Need to go app setting , WhatsApp and re allow it to have access to photos, then it will be able to share via whatsapp
Toader
Since android 13 update I already sense the phone will not get hot already. Plus the transfer speed is very fast 400+ mb/s and card writing speed also seems to maxout to 200+ mb/s. Nice ! This update likely fix the media sound auto soften glitch
eS.KuKu
didn't try the transfer speed, but the phone can feel not so hot already. i play fifa mobile on it
Toader
Video streaming seems very stable after firmware update too (4k YouTube streaming as well)! Will monitor again .
