BuGGi3
- Oct 24, 2002
Is this Artcool series?just my personal experience in view of similar issue despite buying from big electronical agent along with LG or in a way distributor
if there are major issue, buying from small store, likely you will end up nowhere, unless the price negate alot of factors, ie worth more than $500-$1000 of price difference
even though big electronical agent is not that fantastic, at least they have to bear the issue due to they are part of the vicious cycle of their advert, if go to small shop like those aircon cleaning company who also does installing, in the event its not honor, there come the saving part
even LG down own up their issue or take ownership and went MIA
thus hope this helps
compressor change (broke down mutiple time over 2 year, external parts + compressor if base on external company, run up to $4k easily, to LG its nothing since its their own product) , multiple water leaking issue despite regular cleaning -> this boil back to product quality of both product (aircon) + 3rd party installer product (piping)
was quoted few hundred $ to fix the leak thus skip it and let the default warranty cover but need to chase high and low
if this was 3rd party small shop, how it turn out depend on the shop
even aircon cleaning experience after testing quite a few and check their service is not rendered as advertise, can tell alot on the scope of work done too
