Can I check is there any difference between the Wi-Fi 5 and Wi-Fi 6 broadband plan? Is it just that the router they gave is different generation of Wi-Fi.I also just managed to recontract 1Gbps at $34.90 with a pair of Askey WiFi Mesh. Whew...I thought I might have missed the 28 Nov deadline, but the signup page still works.
So if I were to get $34.90 one I can buy a Wi-Fi 6 router and it would still work?
Okay I just signed up with Singtel on the 1Gbps Fiber Plan, and the installation was done yesterday.
Everything fine so far. Bundled with a rubbish Askey WiFi Mesh, a rubbish IPTV Set top box (not even 4K, anyway for free), ONR is Nokia.
Self set-up with 2.5Gbps GPON stick (replace the Nokia G-240-G ONR as no one wants TR-069) and speed test no issue.
The result suggests that Singtel 1Gbps plan comes with bandwidth redundancy at about 1100Mbps (Download)/1010Mbps (Upload).
The following speed test result are taken from PC (2.5Gbps port), first one directly DHCP from NLT to PC, second one from a router with SFP+ port, and 2.5Gbps LAN to PC.
The reasonable hypothesis is that 2Gbps plan will hit >2100Mbps (Download) and >2010Mbps (Upload).
Never test that, I throw away the TV box right when I see it is only HD.
Anyhow it won't affect your internet speed as it is tagged with different VLAN for multiplexing.
Maybe I will try to pull those IPTV m3u8 multicast addresses from Singtel so it can be streamed in any IPTV software in the future, when I am too bored with other entertainments.
good for you.I also just managed to recontract 1Gbps at $34.90 with a pair of Askey WiFi Mesh. Whew...I thought I might have missed the 28 Nov deadline, but the signup page still works.
Need some help.. i trying to connect my TP link Ax5400 to the Singtel ONT.. but i get "No internet connection" error? i thot is plug n play.. anything i missed out?
If i connect to the Singtel Ac9000 modem then the Tp-router work.. mmmm...
I had just re-contract Fibre n TV via their WA chat and choose the cheaper one. Going to get myself a new router to replace my RT-AC68U.good for you.
I miss the deal. The page no longer there.
Today rx Singtel letter, recontract offer 1 GBPS Enhanced plan + Wifi6 @ $42.90
thinking.. should I take up this offer or not
good for you.
Hi bros, if just sign up for Singtel fibre but want to cancel or change plan before installation, anyone knows if it's allowed?
Here's the list of recontract offer:
* 24 mths 1GBPS FHB with Askey Mesh @ $39.90 mthly - $15 bill rebate for 24 mths (UP @ $54.90/mth)
* 24 mths 1GBPS Enhance (WiFi 6) @ $42.90 mthly - $10 bill rebate for 24 mths (UP @ $52.90/mth)
Here's the offer for TV service since you're currently on Action variety Plus
* 12 mths Contract - 50% Discount for 12 mths for Starter of Trio Pack
Thanks for informing. Why would this M1 users dump the GT-AX6000 if it is good? To make a quick buck?Yes this is the normal recontract offer now.
Rrecently there was a superb recontract offer at S$34.90 but I already recontracted before the offer.
And for your case it is good to go with the cheaper S$39.90 plan as you want to upgrade to a better WiFi 6 router from the RT-AC68U.
Depending on your budget, you can go with RT-AX58U/82U/86U/88U or GT-AX6000 as the upgrade for your RT-AC68U. GT-AX6000 is a better buy than RT-AX88U on the higher end since you can get BNIB unit from Carousell (dumped by M1 users).
If you just care for Wireless performance, RT-AX82U is already good enough.
so far I'm okay with Singtel. with them since dialup time.That is the normal offer -- I think it is okay if you have no issues with Singtel.
If you have your own good Wifi 6 router, you can choose the other offer with Askey Mesh.
Currently I on 1G at 39.90 and my contract has end. and I still paying the same price.
Will Singtel suddenly charge me the retail price. or now $39.90 is retail price.
