- Jul 29, 2003
How is Zero 1 compared to Simba? which is more value for $?
Different network cannot compare Apple to orange.. Depends on your needs
S22ultra
i have the $6.90 plan and simba. simba is slower at 20mbps but it is usable even in crowded mrt. even tho zero1 is singtel, it is lower priority so it doesnt work when crowded.How is Zero 1 compared to Simba? which is more value for $?
Depends on where u are also. For my place i am using circles life can get 119.M1 really suck. 50mbps max indoors for me. Vivifi can go up to 110mbps in doors.
These massive concerts are best for comparing between mvno and mno on the same network.Was at mayday conceet yesterday. Got no data connection for 90min +lol cellphone jam
before there were mvno, this was a common problem with ST whenever you attend IT shows at SuntecThese massive concerts are best for comparing between mvno and mno on the same network.
Did u buy the autoroam for USA?Just to share that I’m on $6.90 plan and it works well for me. I am able to receive bank’s OTP when I was in USA.
I did not buy any data roaming from zero1. I changed SIM card for data in USA. When I need bank OTP, I changed back to zero1 sim to get the OTP.Did u buy the autoroam for USA?
You must be local citizen or PR, only for foreigners roaming is disabled.Just to share that I’m on $6.90 plan and it works well for me. I am able to receive bank’s OTP when I was in USA.
| Revised rate for 2023 | Current rate for 2022 | |
| Basic | $7.00 | $6.90 |
| $10.00 | $9.90 | |
| $14.05 | $13.90 | |
| Standard | $18.10 | $17.90 |
| $20.10 | $19.90 | |
| $25.15 | $24.90 | |
| $29.30 | $29.00 | |
| $30.20 | $29.90 | |
| $30.30 | $29.99 | |
| $40.30 | $39.90 | |
| Zero1 5G | $25.15 | $24.90 |
| $32.20 | $31.90 | |
| Jumbo | $12.15 | $12.00 |
| $20.20 | $20.00 |
| $10.00 | $9.90 | |
| $14.05 | $13.90 | |
| $20.10 | $19.90 | |
| $25.15 | $24.90 | |
| $29.30 | $29.00 | |
| $30.20 | $29.90 | |
| $30.30 | $29.99 | |
| $40.30 | $39.90 | |
| $32.20 | $31.90 | |
| $20.20 | $20.00 |
Which plan did you sign up for?Signed up 15 Nov and til now no bill and states no payment needed? But data usage tab is greyed out and no data. How to resume usage?
Zero1 Jumbo 60, the $12 one. Already set default card but til now haven't deduct and no bill. But mobile plan usage is greyed and doesn't show the barsWhich plan did you sign up for?
Weird. I assume your plan is already activated status? I would advise you to email Zero1 at billing@zero1.sg to have them to look into the issue. By right if you have already added your credit/debit card into your Zero1 wallet, you should be on recurring renewal automatically.Zero1 Jumbo 60, the $12 one. Already set default card but til now haven't deduct and no bill. But mobile plan usage is greyed and doesn't show the bars
