reddevil0728
- Dec 16, 2005
Those people facing the same issue should do each other a favour by providing feedback to the relevant authorities so they can look into the systematic issue so that the root cause can be resolved.no.. like I said earlier none of the errors I experienced auto-correct themselves.
the overcharge on 26 Jan has already turned green and I had submitted my claim this morning.
the bill on my card is still pending but the amount is the wrong charge. as from past such incidents, the wrong charge will be billed eventually. then after a few days after submitting the claim I will receive an SMS saying the overcharged amount will be refunded to my card.
idk under what conditions will it autocorrect (some internal audit at LTA? bus companies?) but the system is unreliable. have to check after every trip.
will probably revert to using physical card too as it seems to be more reliable and error-free (before I started using simplygo). those still using phone or smartwatch to tap... just beware and check regularly.
