Google Pixel 7 series
What upgrade would you most like to see on the Pixel 7 series?
  • Total voters
    140
tkte_85
U know why? Because it is CREATIVE and not GOOGLE :s13:
Pun intended...
But on a serious note, my pixel buds pro ok so far
all other bt earphones all work well, just this one. On the other hand, that earphone works on all previous phones except pixel 7 pro. And of course the free pixel buds A work fine
KeYoKe
Got try other BT codec? Try play around the bluetooth options in developer settings?
joesph
how you all know got update? not pushed to me, I read here then I know. thanks
Read HWZ Forum Rules!
mojoe
Was using OP 7 Pro before switching and find that headphone both wired and wireless sounds quite decent with Dolby Atmos....
P7P seems to be on the lacking on this compartment, wondering what 3rd party sound processing app that you guys using to produce better sound quality? I tried Wavelet, not too bad on Spotify, YT Music and etc but it doesn't support TuneIn Radio....
Might be better to get USB dac if you are looking for hi-fi sound.
osmond19
Spatial audio supposedly to be coming in Jan. Wavelet you got enable the legacy mode so that all apps will go through wavelet sound processing?
Yes i enabled the legacy mode but doesn't work with TuneIn, the rest are working.
sigh
What earbuds do you use?
I'm using the Jabra Elite 7 Pro. I think is the the most expensive buds I have ever owned.
Music is so-so.
But calls are really good, Use it on Teams, Whatsapp, Meet etc.
It's like the other party thinks I'm in a quiet room most of the time.
nsd123
For P7p, you might want to use a camera skin asap to prevent scratches on its surface.
Gadgetshieldz can get. Purchased mine and colored G logo for around SGD3. Cheap cheap.
Hi - can I ask where u go this from ? Thx
chuppachop
After the update, if you go settings, battery usage, it now only shows app usage since last full charge. Previously, there is a 24 hrs bar chart where we can see what time, what app was sucking up the battery ... any idea, how to revert to that option?
KeYoKe
No way.... Google changed the way how the battery usage is being presented
elementz
Music is so-so.
I enabled Bluetooth LE audio in developer options and my music quality via bluetooth improved a lot. But my bt earbuds doesn't support LE audio. So I dunno how it works.
