[new] Heya.sg
i_am_fatimah
currently on gomo 5g but feel like not fully utilizing the 5g part
feel like trying heya since its so cheap $10
anyone from gomo 4g ported to heya 4g can share hows the coverage?
keenklee
IMHO.
Coverage is subjective because it depends on your usage location.
If you have dual SIM, why not get a Heya.SG sim and try it out.
According to some feedback, in locations like MRT, Heya.SG is not doing well.
If you are such a user, good to test it out first.
i_am_fatimah
IMHO.
dual sim but 1 port is esim :s13: cant try sadly
maybe stick to gomo then
keenklee
IMHO.
Still possible if only use data. Temporary pop the GOMO into an older mobile for phone call and SMS.
I am using doing something similar to that. My Singtel is on another mobile for calls and SMS. My main mobile uses data is on Heya.SG.
game goondu
IMHO.
I think there is only one vendor.
Use this on the day of expiry
heya $10 50GB 30 Days Plan Top Up / Recharge / Renewal
https://shopee.sg/heya-10-50GB-30-Days-Plan-Top-Up-Recharge-Renewal-i.180756078.17978347944
Use this to put $10 inside your main balance.
heya Main Balance $10 Top Up
https://shopee.sg/heya-Main-Balance-10-Top-Up-i.180756078.21923247982
hi, *119#...
the exp date put 08-12-22...
i must top up on 8th dec or 7th dec is the last day to top up
sango65
This is my heya plan:
Main: $0.00 Exp:05-01-23.
heya Plan: 167.167GB Local Data, Exp:06-12-22. 1997 Local min, Exp:06-12-22. 347 Local SMS, Exp:06-12-22.
My data will expire after 6 Dec 2022 - so I need to top up via shopee vendor by 2359, but I can topup earlier, say 8pm, then my data can rollover
magicianofdk
Would like to check if heya allows a lump sum topup (eg. 100sgd)?
If so, i could not need to worry about topups for the following months. I done that for TPG but not sure about this.
keenklee
IMHO. AFAIK.
You can top up $ to the main balance but it will not auto deduct every month.
I have not top-up $100 but I have done so for $10. When I reach renewal, I have to manually buy the plan.
lohsenglte
Previously when I tested heya, they say it's up to $40 in main balance only.
Not sure if every month will auto renew or must activate via ussd and deduct $10, I gave up using heya after 2 weeks and ported out the line to other telcos and have a way better experience.
Hi1307
Has anyone tried the $5 5G addon on the SingTel app. Does it work on Heya? It let me sign in with my Heya number
darren2190
No auto renewal. And no need worry of overcharge. This is something i like about.
keenklee
Any 1 tried this?
I just bought my first heya SIM today.
Vendor informed that I have to physically visit vendor shops to top up.
I m wondering if this shopee top up circumvents this
IMHO.
Yes. Shopee and Lazada both have.
i_am_fatimah
Any 1 tried this?
this works, tested for my moms phone
under the message column during check out just input the 8 digits mobile phone number can liao
ensure dont put country code
TechNuB
So basically just top up on the date before it expires?
Or can I just top up few months at a go??
Will the seller activate on the same day??
keenklee
IMHO.
Heya got buy data plan and top-up balance.
You need to buy data plan on the day of expiry.
3 days and 1 day before the day of expiry, you will receive an SMS.
Before the official Lazada and Shopee, there is another vendor who does that.
I cannot comment on the official lazada and shopee yet.
The other vendor, less than 1 hour.
