iPad Pro (2022)
ZhouXingXing
which cellular sim plan u all use (or recommend) for your secondary devices like the iPad? Trying to justify the cost or maybe I should just tether via my phone - my concern is the battery life on my phone.
i use sim only plan under circle life $10 for 50gb.. simba also got similar deals too
GotBetrayed
I going to get
Some co can have staff disc too but not much
Think 10%?
I didn’t get cellular since I don’t plan to bring out
Wanted to buy but I calculate pay extra $200, per mth also not little
N since won’t bring out few x then maybe stick with non celluar
First one without n hopefully I make the right decision
did u buy any SP n case? Recommendation? Thanks
I see. For me cellular and eSIM is great, got a lot of flexibility when go out or overseas etc. east activation.
I still thinking about applecare, maybe use 6 weeks later then decide. For me, I have never needed Apple Care for all my apple devices, no case; using it naked. No Magic Keyboard or pencil too.
What is SP?
Snoweagle
Gd???
U take extra SIM card ? I all take cellular n so far this is first one non cellular since I noticed too big I don’t use while on the go
Reach office can use wifi liao
Of course good. Very convenient and 11" is the perfect size for news reading and some mobile gaming.
Laneige
What is SP?
I replaced my charger before with Applecare
Hp wise didn’t do anything but swapped ipad before
Then have the white under light appearing but not sure if old one will have same issues or not … hmm
sp screen protector
I dropped my things easily n use without case for ipad so buy AppleCare will b gd but I think 1 additional yr is bor hua
Shld b 1+2
GotBetrayed
sp screen protector
Shld b 1+2
Yeah I use without case, no SP, love the mini led screen.
Agree that it should be 1+2 for Apple care. 2 years is just rubbish for iPad.
Laneige
Anyone knows the iPad Pro 12.9 latest one nowadays don’t have a sticky film on the screen? I removed the “wrap ard” film n saw marks n prints here n there on the front
Somemore zero battery power
Is it the same as anyone here?
I also received iPhone 14 but it has a film covering the screen
knightcover
Refurbished set?
Matrock5
Just gotten the m2 wifi 11 inch as a gift. What TG and casing you guys using? Which folio is the best?
Snoweagle
Very nice! I bought the 11" M2 cellular last month and using the Logitech Combo Touch with it. If you want just a folio without keyboard, I'd suggest to just go with Apple's folio. Though expensive but good quality.
Matrock5
Thanks! I was considering either a folio or a keypad combo (Logitech), the apple keypad combo is too ex. The apple folio is not cheap too haha.
By the way cellular vs wifi why did u decide to get the cellularversion? Not sure for myself wifi is sufficient or one with cellular.
Snoweagle
All the while I’ve been using a wifi iPad (mini) and got tired of tethering. Cellular is so much more convenient.
I don’t deny that I wanted to get the Magic Keyboard but it’s really expensive and it’s just a keyboard for you to attach your iPad onto and serves no protection to the sides of the iPad. I usually will use my iPad to read news and articles on the go but if you have the Magic Keyboard, you to detach the iPad and use it bare. On the Combo Touch I just detach the keyboard, flip it around, re-attach it and stow it behind.
Matrock5
Took the plunge and purchased the logi combo touch during Xmas Shopee sales thanks to Snoweagle bro for the recommendation.
Snoweagle
You'll enjoy it. So far to me still the best keyboard case (with trackpad) for the iPad Pro. If Apple's offering is able to use in read mode without removing the iPad from the case and still offer side protection with function keys, I'd definitely buy it. Even the Magic Keyboard Folio for the 10th gen iPad has function keys and designed just like the Logitech Combo Touch with detachable keyboard.
The Magic Keyboard is a bit outdated and needs a re-design IMO.
Matrock5
Thanks. I wanted to ask for my model which is just the wifi version model no A2759 which is not listed under the compatible models in the Logitech website in Shopee does it mean it is not compatible? The wifi cellular model A2435 is listed in the website though.
Snoweagle
No info on this though, it should be compatible with all models.
stupidog
do u think 12.9" can replace a macbook pro ?
i am lazy to lug my mbp 16" during travelling.
