Real International speed tests
What ISP are you testing on?
  • Total voters
    64
seowbin
9PM from a VM machine in moi ISP wannabe network. Ignore the China latency. End user won't get that kind of latency . Still working on it.
This is without optimization :s34:
let's see can pump up the speed or not after this
Server NameServer IDLatencyJitterPacket LossDownload SpeedUpload SpeedTotal DownloadedTotal Uploaded
ViewQwest - Singapore20540.7 ms0.08 ms0.00%7033.0 Mbps5170.71 Mbps52,393 MB70,005 MB
PT FirstMedia - Singapore75560.8 ms0.04 ms0.00%6129.71 Mbps6983.97 Mbps36,885 MB77,268 MB
Comcast - Sacramento, CA9436173.7 ms0.05 ms0.00%1691.63 Mbps431.77 Mbps18,775 MB5,608 MB
Spectrum - Los Angeles, CA16974185.48 ms0.01 ms0.00%1624.45 Mbps251.02 Mbps17,247 MB3,342 MB
University of Texas, Austin - Austin, TX16089210.32 ms0.16 ms0.00%394.78 Mbps60.58 Mbps3,126 MB801 MB
Optus - Melbourne30932112.49 ms0.67 ms0.00%1692.58 Mbps658.15 Mbps22,318 MB4,347 MB
Misaka Network, Inc. - Tokyo4498877.56 ms0.14 ms202.43%4066.95 Mbps126.18 Mbps54,652 MB1,759 MB
SIMPLYCONNECT - Dar es Salaam13902316.23 ms2.28 ms0.00%3.82 Mbps18.99 Mbps38 MB263 MB
Celcom Axiata - Kuala Lumpur49569.06 ms0.2 ms0.00%8833.36 Mbps186.17 Mbps89,613 MB2,479 MB
Bell Mobility - Vancouver, BC17402195.31 ms0.05 ms0.00%1522.72 Mbps263.43 Mbps17,154 MB3,554 MB
Telstra International - Hong Kong4434031.45 ms0.07 ms0.00%1660.14 Mbps5686.07 Mbps22,532 MB80,785 MB
ChinaTelecom 5G - Guangzhou2759492.07 ms0.54 ms507.61%64.12 Mbps6.63 Mbps705 MB120 MB
China Telecom - Shanghai363391.36 ms1.33 msN/A96.85 Mbps36.38 Mbps1,262 MB437 MB
cyberet
Interesting, after changing the client's DNS server to the router instead of directly to the ISP, I get 14 results instead of 11.
Singtel - Singapore136233.21 ms0.14 ms100.00%904.48 Mbps841.15 Mbps5,636 MB11,223 MB
ViewQwest - Singapore20542.66 ms0.25 ms0.00%557.47 Mbps590.56 Mbps4,020 MB4,797 MB
PT FirstMedia - Singapore75567.0 ms0.77 ms0.00%338.08 Mbps863.46 Mbps4,834 MB11,969 MB
Comcast - Sacramento, CA9436214.01 ms0.35 ms0.00%16.16 Mbps48.4 Mbps167 MB641 MB
Spectrum - Los Angeles, CA16974183.48 ms0.71 ms41.49%10.32 Mbps7.64 Mbps120 MB109 MB
University of Texas, Austin - Austin, TX16089223.05 ms289.56 ms41.67%45.06 Mbps11.42 Mbps533 MB91 MB
Optus - Melbourne30932224.82 ms1.84 ms82.99%331.94 Mbps22.57 Mbps3,745 MB325 MB
Misaka Network, Inc. - Tokyo4498876.15 ms151.89 ms0.00%147.42 Mbps55.82 Mbps1,685 MB961 MB
SIMPLYCONNECT - Dar es Salaam13902316.29 ms2.47 ms0.00%3.09 Mbps6.65 Mbps30 MB63 MB
Celcom Axiata - Kuala Lumpur495613.14 ms3.85 ms47.17%174.7 Mbps248.96 Mbps2,014 MB3,919 MB
Bell Mobility - Vancouver, BC17402154.0 ms0.18 ms82.99%91.48 Mbps91.06 Mbps979 MB1,170 MB
Telstra International - Hong Kong4434036.81 ms0.24 ms125.00%58.25 Mbps141.12 Mbps694 MB2,071 MB
ChinaTelecom 5G - Guangzhou27594240.96 ms232.07 ms711.30%6.79 Mbps1.84 Mbps79 MB13 MB
China Telecom - Shanghai3633432.61 ms641.59 msN/A51.59 Mbps0.58 Mbps566 MB8 MB
dudley02
M1 1 Gbps
Singtel - Singapore136234.19 ms0.05 ms0.00%843.71 Mbps664.02 Mbps
ViewQwest - Singapore20543.78 ms0.16 ms0.00%862.76 Mbps647.91 Mbps
PT FirstMedia - Singapore75563.32 ms0.15 ms0.00%849.02 Mbps656.14 Mbps
Comcast - Sacramento, CA9436192.69 ms0.08 ms0.00%201.01 Mbps383.08 Mbps
Spectrum - Los Angeles, CA16974194.21 ms0.17 ms0.00%121.43 Mbps452.21 Mbps
University of Texas, Austin - Austin, TX16089204.31 ms0.21 ms0.00%103.56 Mbps146.67 Mbps
Optus - Melbourne30932109.75 ms0.1 ms0.00%568.46 Mbps715.92 Mbps
Misaka Network, Inc. - Tokyo4498870.63 ms0.67 ms34.97%536.49 Mbps107.13 Mbps
SIMPLYCONNECT - Dar es Salaam13902357.19 ms7.21 ms0.00%15.54 Mbps4.28 Mbps
Celcom Axiata - Kuala Lumpur495613.43 ms0.2 ms0.00%693.42 Mbps677.82 Mbps
Bell Mobility - Vancouver, BC17402226.18 ms0.3 ms0.00%412.72 Mbps429.1 Mbps
Telstra International - Hong Kong4434032.8 ms0.07 ms0.00%643.98 Mbps658.19 Mbps
ChinaTelecom 5G - Guangzhou27594351.5 ms8.48 ms37.59%39.7 Mbps32.69 Mbps
China Telecom - Shanghai3633312.19 ms3.81 msN/A347.77 Mbps195.47 Mbps
M1 1 Gbps
Hmm, your M1 results seem to be on the low side. Are you using wireless or wired?
If using wired, what are the router and client used?
Using wired connection (Acer Swift 3 Windows 11 laptop with Ugreen USB 3.0 to Gigabit Ethernet adaper).
Singtel 1Gbps plan, Singtel ONT, Asus RT-AX82U router.
ServerLatencyDownloadUploadLoss
Singtel - Singapore (id = 13623)1.96ms (Jitter = 0.18ms)943.53Mbps (data used: 3.8GB)946.63Mbps (data used: 8.9GB)0.00%
ViewQwest - Singapore (id = 2054)37.41ms (Jitter = 0.37ms)805.46Mbps (data used: 9.4GB)946.17Mbps (data used: 9.4GB)0.00%
PT FirstMedia - Singapore (id = 7556)3.8ms (Jitter = 0.38ms)908.53Mbps (data used: 10.3GB)946.13Mbps (data used: 8.9GB)0.00%
Comcast - Sacramento, CA (id = 9436)185.67ms (Jitter = 0.4ms)182.45Mbps (data used: 1.9GB)379.08Mbps (data used: 3.7GB)0.00%
Spectrum - Los Angeles, CA (id = 16974)195.57ms (Jitter = 0.43ms)278.08Mbps (data used: 3.3GB)344.09Mbps (data used: 3.2GB)0.00%
Optus - Melbourne (id = 30932)110.94ms (Jitter = 0.32ms)817.7Mbps (data used: 10.1GB)462.04Mbps (data used: 6.6GB)0.00%
Misaka Network, Inc. - Tokyo (id = 44988)232.45ms (Jitter = 38.44ms)74.27Mbps (data used: 0.8GB)236.53Mbps (data used: 2.9GB)0.00%
SIMPLYCONNECT - Dar es Salaam (id = 13902)504.64ms (Jitter = 0.68ms)3.71Mbps (data used: 0.0GB)0.72Mbps (data used: 0.0GB)478.09%
Celcom Axiata - Kuala Lumpur (id = 4956)76.02ms (Jitter = 0.29ms)662.51Mbps (data used: 8.7GB)946.8Mbps (data used: 9.8GB)0.00%
Bell Mobility - Vancouver, BC (id = 17402)362.93ms (Jitter = 1.76ms)215.5Mbps (data used: 2.1GB)1.38Mbps (data used: 0.0GB)592.59%
Telstra International - Hong Kong (id = 44340)33.4ms (Jitter = 0.23ms)761.66Mbps (data used: 9.3GB)946.35Mbps (data used: 9.4GB)0.00%
ChinaTelecom 5G - Guangzhou (id = 27594)349.1ms (Jitter = 0.79ms)47.11Mbps (data used: 0.5GB)37.6Mbps (data used: 0.5GB)0.00%
China Telecom - Shanghai (id = 3633)188.42ms (Jitter = 3.98ms)334.77Mbps (data used: 4.1GB)12.38Mbps (data used: 0.2GB)N/A
Another result.
Singtel 1Gbps plan, Singtel ONT, Intel J4105 mini PC running OpenWRT 22.03 Virtual router + Singtel Mesh Router as AP
Singtel - Singapore (id = 13623)2.26ms (Jitter = 0.13ms)946.41Mbps (data used: 6.0GB)942.92Mbps (data used: 9.3GB)0.00%
ViewQwest - Singapore (id = 2054)37.62ms (Jitter = 0.26ms)812.84Mbps (data used: 10.2GB)880.56Mbps (data used: 11.1GB)0.00%
PT FirstMedia - Singapore (id = 7556)3.89ms (Jitter = 0.18ms)886.93Mbps (data used: 5.5GB)943.3Mbps (data used: 9.0GB)0.00%
Comcast - Sacramento, CA (id = 9436)185.82ms (Jitter = 0.68ms)190.65Mbps (data used: 2.1GB)399.78Mbps (data used: 3.9GB)0.00%
Spectrum - Los Angeles, CA (id = 16974)181.48ms (Jitter = 0.57ms)214.65Mbps (data used: 2.6GB)375.9Mbps (data used: 3.6GB)0.00%
Optus - Melbourne (id = 30932)113.12ms (Jitter = 0.31ms)810.49Mbps (data used: 9.8GB)443.87Mbps (data used: 5.0GB)0.00%
Misaka Network, Inc. - Tokyo (id = 44988)251.61ms (Jitter = 40.33ms)184.94Mbps (data used: 1.9GB)241.56Mbps (data used: 3.1GB)0.00%
SIMPLYCONNECT - Dar es Salaam (id = 13902)486.4ms (Jitter = 1.63ms)1.82Mbps (data used: 0.0GB)0.33Mbps (data used: 0.0GB)1405.62%
Celcom Axiata - Kuala Lumpur (id = 4956)75.43ms (Jitter = 0.25ms)608.2Mbps (data used: 8.0GB)595.66Mbps (data used: 8.6GB)0.00%
Bell Mobility - Vancouver, BC (id = 17402)357.52ms (Jitter = 264.73ms)116.18Mbps (data used: 1.2GB)0.71Mbps (data used: 0.0GB)2243.90%
Telstra International - Hong Kong (id = 44340)35.15ms (Jitter = 0.33ms)811.18Mbps (data used: 10.1GB)843.59Mbps (data used: 12.1GB)0.00%
ChinaTelecom 5G - Guangzhou (id = 27594)343.32ms (Jitter = 8.23ms)17.57Mbps (data used: 0.2GB)87.81Mbps (data used: 0.9GB)0.00%
China Telecom - Shanghai (id = 3633)189.35ms (Jitter = 0.51ms)313.91Mbps (data used: 3.6GB)18.95Mbps (data used: 0.3GB)N/A
probablye
MyRepublic 1Gbps
Singtel - Singapore136231.97 ms0.18 ms0.00%951.6 Mbps949.23 Mbps
ViewQwest - Singapore20542.4 ms0.2 ms0.00%936.32 Mbps949.09 Mbps
PT FirstMedia - Singapore75562.16 ms0.27 ms0.00%944.63 Mbps949.05 Mbps
Spectrum - Los Angeles, CA16974242.44 ms0.19 ms0.00%640.27 Mbps56.62 Mbps
University of Texas, Austin - Austin, TX16089203.47 ms0.27 ms0.00%105.21 Mbps8.58 Mbps
Misaka Network, Inc. - Tokyo4498883.97 ms0.15 ms0.00%802.7 Mbps36.64 Mbps
SIMPLYCONNECT - Dar es Salaam13902254.52 ms0.31 ms0.00%8.78 Mbps9.77 Mbps
Celcom Axiata - Kuala Lumpur495612.94 ms0.09 ms0.00%929.06 Mbps281.25 Mbps
Telstra International - Hong Kong4434033.98 ms0.13 ms0.00%914.25 Mbps274.62 Mbps
ChinaTelecom 5G - Guangzhou27594232.0 ms0.38 ms0.00%347.1 Mbps9.89 Mbps
seowbin
Here's a result during 9AM in my ISP wannabe network
Same thing, ignore China result :D
Don't know why Singtel result always doesn't appear. it works while behind firewall :s13: what the......
this VM is directly connected to internet.
ViewQwest - Singapore20540.96 ms0.04 ms0.00%9409.61 Mbps5823.33 Mbps84,541 MB46,188 MB
PT FirstMedia - Singapore75560.73 ms0.02 ms0.00%7609.1 Mbps8372.04 Mbps38,937 MB76,237 MB
Comcast - Sacramento, CA9436174.09 ms0.03 ms0.00%1784.32 Mbps448.76 Mbps19,737 MB4,197 MB
Spectrum - Los Angeles, CA16974247.91 ms0.12 ms0.00%1470.24 Mbps111.91 Mbps16,314 MB1,604 MB
University of Texas, Austin - Austin, TX16089236.66 ms1.65 ms0.00%2950.59 Mbps23.33 Mbps26,674 MB309 MB
Optus - Melbourne30932112.58 ms0.1 ms0.00%1787.24 Mbps804.88 Mbps23,474 MB7,849 MB
Misaka Network, Inc. - Tokyo4498880.51 ms0.47 ms0.00%7588.84 Mbps205.93 Mbps99,704 MB3,001 MB
SIMPLYCONNECT - Dar es Salaam13902316.57 ms0.13 ms0.00%3.96 Mbps4.24 Mbps58 MB57 MB
Celcom Axiata - Kuala Lumpur49569.26 ms0.03 ms0.00%9056.55 Mbps235.35 Mbps98,433 MB2,822 MB
Bell Mobility - Vancouver, BC17402192.07 ms0.1 ms0.00%1600.75 Mbps346.73 Mbps18,167 MB4,586 MB
Telstra International - Hong Kong4434031.85 ms0.04 ms0.00%1679.41 Mbps3156.61 Mbps22,708 MB44,071 MB
ChinaTelecom 5G - Guangzhou2759468.68 ms0.33 ms0.00%53.26 Mbps1.49 Mbps719 MB65 MB
China Telecom - Shanghai363373.3 ms0.22 msN/A91.56 Mbps58.83 Mbps933 MB760 MB
lexisnexus
M1 result, at 11:40 AM
server nameserver idlatencyjitterpacket lossdownloadupload
Singtel - Singapore136233.97480.200250946.43946.69
ViewQwest - Singapore20543.96780.078750915.92938.57
PT FirstMedia - Singapore75563.62010.17450890.07938.66
Comcast - Sacramento, CA9436183.9260.12050823.52460.84
Spectrum - Los Angeles, CA16974179.3210.102250655.88455.77
University of Texas, Austin - Austin, TX16089222.6380.08450.353357215.00165.56
Optus - Melbourne30932217.3890.1050695.61268.68
SIMPLYCONNECT - Dar es Salaam13902248.9130.248022.930.98
Celcom Axiata - Kuala Lumpur495614.28710.133250926.42252.13
Bell Mobility - Vancouver, BC17402224.3280.172250859.30281.64
Telstra International - Hong Kong4434035.12110.09850937.88936.12
ChinaTelecom 5G - Guangzhou27594417.55810.4578015.596.11
China Telecom - Shanghai3633389.0629.5892N/A14.977.62
Henry Ng
Such speed test result is not real world internet speed as different website will do their own internet traffic shading la. User has no control over such DL and UL speed la. Such speed test only proof that nothing wrong with your home network la.
lexisnexus
But can prove there is something "wrong" with China side. :sneaky::sneaky:
firesong
Deluxe Member
Yes but nothing we can do la. Sad la.
Yeah, nothing we can do. But doesn't mean it's useless.
Sending a track record of this is proof that a problem exists. Better than not having anything at all, which is the point of tools like Smokeping that automate and chart this process.
Henry Ng
Just wondering whether it is China traffic shaping the internet connection. May be it is their China Firewall doing deep package inspection.
seowbin
if you want to access china below 100ms , provider have to pay premium for it
otherwise, typically it go via US . 300MS is normal (CN-> US -> SG) .
