Google Pixel Watch
HMAN
Same. I got it ard $7+ from shopee too. Just received the charger and it is working.
may I know which store exactly you get? would like to buy from a known store.
getting frustrated, Lazada most stores have no stock but fooling customers to place order, after securing the order, they then take the own sweet to order, some more they will declare items packed such that user can't cancel the order.
Read HWZ Forum Rules!
osmond19
Can share the link here? https://shopee.sg/product/96460236/23810594008?smtt=0.73875673-1672837583.3 Think the seller upz the price by few cents.
osmond19
Anyway, anyone manages to add their citibank cashback into the Google Wallet. I have no issue to add it into my P7P Google Wallet but failed to add it into my watch's wallet. By right, it will prompt to enter OTP when I added it on my phone but on watch, it didn't... Who should I call to resolve this? Bank or Google Support?
The rest of my CC from POSB and Amex no issue except for Citibank.
Sauron
Citibank card cannot be added for me too
crow_nest
Been a problem for months now. Alr contacted citibank twice to reset the "tokens" and still no use. Contacted google support and they also keep giving me same replies saying they will escalate and work on it. But it was never been fixed for me. Did some searching and found out that ppl in other countries also have issues adding citi cards, so we're not alone. Most likely an issue on google's back end already.
You can add it just fine to your phone's wallet, but not the watch.
osmond19
i see... initially i was thinking if it is become Citibank has more built in security to their card. recently, citibank added some security that if you add a new account for transfer (not paynow), they will let u immediate transfer fund to the account and need to wait for 24 hours before u can transfer.
based on my own testing, i think something is not wrong when adding citibank credit card in the watch as it did not trigger the OTP input while it will trigger if u add it to the phone.
osmond19
have anyone using the Watch Google Wallet to take public transport with POSB everyday card?
I too realise even if i double press the crown to launch the wallet and set the card as default, it takes couple of sec for the watch to registered a scan on the tapping machine. If u use phone wallet to tap, the tap is almost instant.
The lag might be caused the ppl behind to irritate ppl behind me.... sometimes, i just hv to take out my phone to tap/ scan instead.
HMAN
yes it is slow to invoke the card.
touch and swipe down the menu screen to tap on the wallet icon does not need to wait so long.
I have anxiety problem to use my watch to take bus, worrying bus captain will run away without waiting for me to complete the transaction.
osmond19
There is once the bus moved off and i yet to tap and got to stand at the front door for the bus to reach another bus stop before i can tap with my phone instead...
Now ended up I use my phone with is almost instant tap as long as the screen is on on public transport.
alanchia67
Just double click when you get off the bus seat to walk to the door. More than enough time to get the wallet app running.
osmond19
I did that but it is still very slow to register the tap vs using phone or even ezlink card
alanchia67
Make sure the strap is tight (but still comfortable) so that the watch do not have to detect is it being worn.
osmond19
I wear my watch just now not too tight or loose... Anyway i just use the phone to tap on public transport to prevent causing a jam behind me.
limmk
This update takes you to the January 5, 2023 security patch level. RWD9.220429.073 is the new build number with a RWD9.220429.073.J1 variant for watches in Japan and Taiwan. Google’s changelog highlights one key fix related to older clock faces that don’t use the Jetpack Watch Face library:
  • Fix to address 3rd party watch faces turning off after 15 mins with always on display (AOD) enabled.
alanchia67
Just curious, do you have non-google third-party app installed? For example third-party watch facer? Try uninstalling third-party apps.
The watch wallet performance should be very similar to the phone. My Pixel Watch and Pixel 6pro has about the same response time.
HMAN
it is the wallet loading time from watch is slower than phone.
osmond19
How to get this update? On the watch it said up to date and android security updates still stuck at 5 dec 2022?
