Asus CT8 with SingTel
ah_cleo
I am on singtel 1gbps using ONT. I understand i need to set the profile SingTel-Others.
Which means the last port is for SingTel TV. Can i manual configure the vlan tagging for port 3 to use as internet as i do not have SingTel TV
Based on what i read,
Select "manual configuration" and then put "VID: 10; PRIO: 0" for all three, Internet, LAN Port 3, LAN Port 2.
will it works?
will it works?
Yes that should work.
ah_cleo
Actually i tried and it unfortunately doesnt work. But if i set back to SingTel-Others, it works. But my lan 3 become iptv which i am not using. Weirdddd
ah_cleo
Anyone managed to get it to work by manually configuring vlan on SingTel?
xonix
You may want to contact Asus for help.
I think the preset was initially created as a workaround for Singtel vlan. Doubtful Asus will be able to help what is a "problem" created by Singtel.
For other Asus routers, it is possible to use manual VLAN configurations. So there may be problems with CT8.
xonix
Hello,
These are the VLAN tagging:
Internet: VLAN 10 prio 0
MIOTV: VLAN 20 prio 4
If you have digital voice i recommend you ask singtel to put it on your singtel ONT(there's a rj11 port for TEL1)
By default some ASUS singtel presets will put LAN 3 for IPTV and LAN 4 for MioVoice
Is probably why your LAN4 doesn't work for IPTV.
If your router allows you to customize your VLAN tagging,
Maybe set:
LAN 1-3 : VLAN 10 Prio 0
LAN 4: VLAN 20 prio 4
also note that your LAN 4 should connect to their MIOtv Box then to the TV via HDMI and not connected directly to your TV via Ethernet cable.
Pic of MIOTV box:
You should read the thread from top to bottom first.
ah_cleo
Weird that i manual input the vlan also dun work
ah_cleo
End up i got razer sila and it works like a charm easily.
Asus.... *shake head*
