GPU & CPU for Cyberpunk @4K
R6exR6
What's the Minimum GPU & CPU needed for playing Cyberpunk @4K 60fps Ultra RT-DLSS Quality?
summer_dell
3080ti,
rx6950 (ignore, just realized u wanted RT )
3090
3090ti
4080
4090
All these should work reasonably well.
for cpu, i think 12th gen i7 onwards should be ok
R6exR6
Thanks!
Since the 4090 can get ~100fps on 4K Max RT Psycho / DLSS Quality / FG, I'm sure the 4080 16GB can get >60fps as well.
Do you think 4070 Ti 12GB can get 60+fps for 4K Max RT Psycho / DLSS Quality / FG?
R6exR6
3080ti,
3090
3090ti
4080
4090
Thanks.
Guess the minimum will be 12700 + 3080 Ti.
NightRaven49
nope, minimum gpu is 4090, as per the videos tigerwoods has provided. 4080 does barely 60fps with dlss and rt ultra (not psycho), 3090ti will only be 45fps or so, 3080ti even less. see below @ 18:39 (with 5800x3d):
R6exR6
nope, minimum gpu is 4080, and even then it is barely 60fps with rt ultra (not psycho). 3090ti with dlss will only be 45fps or so, 3080ti even less. see below @ 18:39 (with 5800x3d):
Noted.
Guess my next card I buy will 4080, 5070, or something newer.
Don't want the 4090 - too expensive and too hot and power-hungry.
R6exR6
How about the i5-13400F?
Good enough for the above stated requirement?
I mean, I only need 60fps with CP Ultra RT DLSS-Quality FG after all .....
R6exR6
tigerwoods
Lucky me then ... šŸ˜…
I pre-ordered the game, but hasn't gotten around to play it yet (coz work stress, then PC mobo died, then stopped gaming for a couple of years).
Now retired and finally got time to get back into gaming ... LOL
So good life retired, how old are you?
R6exR6
The video seems to indicate the use of DLSS 2.
Thus, I'm guessing, with DLSS 3 (including frame generation), even the 4070 Ti can hit 60fps at my desired settings. Why? Coz the 2nd video from the top showed DLSS 3 increased fps from 60 to 100, so by the same proportion, the 3090 Ti's (equivalent to 4070 Ti) 45 fps will likely just manage to jump past 60fps (with DLSS 3 on 4070 Ti).
55. Retired at 52. Hates work! Only have enough $$ for simple lifestyle, but still beats working! šŸ˜…
abstrax
of coz is RTX 4090 the best!!!!!
CPU = i feel 11th gen i7 onwards will do.
And u will need a NVMe SSD for fast loading.
R6exR6
Bro, I was asking only for the MINIMUM GPU that will meet my stated requirement la ... not which is the best card. šŸ˜… If a 4070 Ti can give me what I need, then I don't need to spend so much for a 4090. I'm not rich.
Regarding the 11th gen i7, then I guess even the i5-13400F or i5-12400F will be good enough, coz all three have similar performance it seems:
https://www.cpubenchmark.net/compar...i7-11700-vs-Intel-i5-13400-vs-Intel-i5-12400F
-Grift-
5900x + 4080
@ 3840x1600
Ultra-ish settings with DLSS Quality can do about 50-80 fps
tigerwoods
4070 Ti with DLSS 3 will be fine with 60 to 100fps.
But do you really must play in 4K, play with a good 1440p monitor is good enought.
