What's the Minimum GPU & CPU needed for playing Cyberpunk @4K 60fps Ultra RT-DLSS Quality?
Thanks.3080ti,
rx6950 (ignore, just realized u wanted RT )
3090
3090ti
4080
4090
All these should work reasonably well.
for cpu, i think 12th gen i7 onwards should be ok
nope, minimum gpu is 4090, as per the videos tigerwoods has provided. 4080 does barely 60fps with dlss and rt ultra (not psycho), 3090ti will only be 45fps or so, 3080ti even less. see below @ 18:39 (with 5800x3d):Guess the minimum will be 12700 + 3080 Ti.
Noted.nope, minimum gpu is 4080, and even then it is barely 60fps with rt ultra (not psycho). 3090ti with dlss will only be 45fps or so, 3080ti even less. see below @ 18:39 (with 5800x3d):
Lucky me then ...Not playing Cyberpunk 2077 till they fix the game, it's still full of bugs.
https://www.inverse.com/gaming/cyberpunk-2077-edgerunners-night-city-is-empty
So good life retired, how old are you?Lucky me then ...
I pre-ordered the game, but hasn't gotten around to play it yet (coz work stress, then PC mobo died, then stopped gaming for a couple of years).
Now retired and finally got time to get back into gaming ... LOL
The video seems to indicate the use of DLSS 2.nope, minimum gpu is 4090, as per the videos tigerwoods has provided. 4080 does barely 60fps with dlss and rt ultra (not psycho), 3090ti will only be 45fps or so, 3080ti even less. see below @ 18:39 (with 5800x3d):
55. Retired at 52. Hates work! Only have enough $$ for simple lifestyle, but still beats working!So good life retired, how old are you?
of coz is RTX 4090 the best!!!!!What's the Minimum GPU & CPU needed for playing Cyberpunk @4K 60fps Ultra RT-DLSS Quality?
Bro, I was asking only for the MINIMUM GPU that will meet my stated requirement la ... not which is the best card.of coz is RTX 4090 the best!!!!!
CPU = i feel 11th gen i7 onwards will do.
And u will need a NVMe SSD for fast loading.
4070 Ti with DLSS 3 will be fine with 60 to 100fps.The video seems to indicate the use of DLSS 2.
Thus, I'm guessing, with DLSS 3 (including frame generation), even the 4070 Ti can hit 60fps at my desired settings. Why? Coz the 2nd video from the top showed DLSS 3 increased fps from 60 to 100, so by the same proportion, the 3090 Ti's (equivalent to 4070 Ti) 45 fps will likely just manage to jump past 60fps (with DLSS 3 on 4070 Ti).
55. Retired at 52. Hates work! Only have enough $$ for simple lifestyle, but still beats working!![]()
