Phen8210
- Jul 29, 2011
Unfortunately, I feel that proper HDR for PC gaming is still way too expensive for most people. A good mini LED or OLED monitor will set one back by over 1.5K now. You can get TV for around 2K, but its too big for me to use as a monitor.
Yeah.. too expensive. Most HDR on monitors like HDR400 is actually not very impactful.
A lot of monitors will purposely dim the display in HDR mode, and make colors appear more vibrant to give the user a false impression of what HDR is, but that's not what HDR is supposed to be.
The last time I deliberately tuned a monitor HDR400 mode settings to make it look similar to its SDR mode (both colors and brightness-wise) by calibrating it based on normal content. This also includes setting the brightness balance between HDR and SDR to be neutral on windows.
After removing all these external factors, I put up HDR content and switched between HDR/SDR and realized that the difference became very subtle.
This means the difference many people see in these 'HDR400' monitors is actually mostly not an 'HDR' experience. A lot of the difference seen actually mostly has nothing to do with HDR, it was the results of other settings.
When I did the same thing on a true HDR panel, it still had a massive difference regardless.
