86technie
- Jun 8, 2006
Sure.Thanks, would you mind if I PMed you?
i dont think best denki has upgrading services but i could be wrong...You can consider getting this with your tight budget.
https://www.bestdenki.com.sg/2916377-lenovo-desktop-ic-3-90sm002qst.html
Ask the shop how much it will cost to upgrade to 16GB, 16GB RAM shouldn't cost
more than $100.
RAM upgrade they should have, the rest like upgrade hard disk/SSD maybe they don't have.i dont think best denki has upgrading services but i could be wrong...
Cannot believe my eyes...You can consider getting this with your tight budget.
more than $100.
You can buy pre-built.. or even one of the mini PC around since you dun game.. then get an extra external HDD to transfer file lor.. but since you said desktop died.. you might have to get some sort of enclosure to access the files in your old desktop.. but you need to check if it is 2.5" or 3.5" before you buy the enclosure.Recommendation needed
Desktop just died.
I am old person non gamer.
Looking for a new desktop compueter. Budget around 1K. No need monitor.
Need also help to transfer file to new PC.
Should i get a USB data transfer cable or use window one? can already?
thanks![]()
What's your use case?Recommendation needed
Desktop just died.
thanks![]()
Cannot believe my eyes...got people sell desktop with just 4GB RAM... really follow minimum required for Windows 11... and best part.. still costs $806...
Beelink GTR5 Mini PC Wi11 Pro, AMD Ryzen 9 5900HX (up to 4.6GHz), Mini Gaming Computer 32GB DDR4 500GB NVMe SSD, Mini Desktop Computer 4K@60Hz Three Screen Display WiFi 6E BT5.0
https://www.amazon.sg/dp/B0B45ZQ8M3...d&sr=1-2-ac08f2b1-eb5b-4f1a-aa64-9e8f448c33ed
Saw this on Amazon SG... stocks should be local fulfilled by Amazon but might not have warranty (This one got to check)... but now got promo only $749... and pre-installed with Win 11 Pro.. there are review on YouTube...
thanksYou can buy pre-built.. or even one of the mini PC around since you dun game.. then get an extra external HDD to transfer file lor.. but since you said desktop died.. you might have to get some sort of enclosure to access the files in your old desktop.. but you need to check if it is 2.5" or 3.5" before you buy the enclosure.
The old PC is lenovo about 8 yrs old.What's your use case?
If you mean browser with many tabs.. I think it is more of a memory thing.. but I think most PC with at least 16GB should be fine.. unless on top of browser you still need to use other software that would take up substantial amount of memory.. then maybe need to consider 32GB...thanks
i am a noob on tech matter.
The old PC was a lenovo. Not sure if it is 2.5 or 3.5 inch.
Manly use to surf (edmw included}
I like to open many browser and
speed is important as need to do some internet booking.
Where is like a few thousand people rushing for 3 slots available.
So what is moreimportant for me?
Memory, CPU speed or graphics card?
tq
Was actually referring to this, use case as in what intended purpose/usage.thanks
tq
Agree w BlackWing1977, memory is your paramount concern, the rest can just make do.If you mean browser with many tabs.. I think it is more of a memory thing.. but I think most PC with at least 16GB should be fine.. unless on top of browser you still need to use other software that would take up substantial amount of memory.. then maybe need to consider 32GB...![]()
As test I made sure I got 80 tabs are loaded... as I use ccleaner to do a sweep each morning, it is using about 5.6GB... so if you are like me sometimes game with the browser in the background can experience some sort of lagging sometimes.. especially if you are on 16GB... but most of the time is okay... I mean typical usage is a browser, maybe whatsapp, discord, steam software.. one to two file explorer windows open that to me is around 87% of my memory taken up and that is before I play any game.Was actually to this, use case as in what intended purpose/usage.
thank youWas actually to this, use case as in what intended purpose/usage.
