my short review : Not goodHi boss, any reviews on the Redroad G10? Is there a repair workshop/local warranty for the robot?
Sorry for the late post, been busy at work!
if u can get 10% qoocoins, this is damn value for money:
I got the RedRoad G10 exactly 1 month ago, but then was down with Covid19 for 2 weeks just after i got it.
But, i did find time to open it up and test, and also mop the floor everyday while i home quarantined!
Here's part 1 of the review first, some unbox shots!
Packing is decent and compact as it can get.
The robot itself is pretty standard quality, the water tank feel good, though i really wish they made the dirty tank clear so that i can see the dirty water!
Part 2 of the Redroad G10 review.
Some simple walkthrough, i'll give my thoughts near the end.
Software is actually quite decent, all the options are there.
I didn't realised there are more cleaning options at the bottom of the screen and i NEEDED to SWIPE down..
Custom Clean allows you to select each room and set the following options:
1. 1 or 2 times cleaning
2. vac, vac + mop, mop
3. Suction level (4 levels)
Suction is pretty decent, when you set to silent, it's not too loud, i can sleep thru it.
There are quite many options in the advanced menu, quite elaborate i must say.
Most Options have sub-text with explanation, pretty good!
Quick map creation allows the robot to move thru your place and scan the map without working.
Carpet settings allow you to set carpet pressurization mode, avoidance mode and display mode.
Mopping mode can set S-shape (faster) or Y-shape (cleaner).
Edge and Secondary (2x) cleaning are a one-time thing, works only for the next clean job.
You can't use Edge cleaning in Schedule mode, unlike Hydra which i can set.
Water Electrolysis is my favorite! It's supposedly electrolyzes the water used to clean the mop, thus sterelizing it and reducing germs and odour in the waste water!
I don't know how effective is it or what, but i know the dirty water tank is less smelly!
The voice prompt is completely garbled sometimes, i don't even know what it is saying! but whatever..
at least it's making noise so i know it's working/something is wrong.
This above is my cleaning records for the last month, i use it almost once a day or 2-3 times some days then rest a few days.
App Speed: Decently fast, definitely faster than Mi Home robots.
You can choose NA / EU / ASIA server, I use the EU server as it felt faster than the SG server, it connects to eu-ota.3irobotix.net.
I initially setup the robot and mapped the place using ASIA server, but changed to EU server by setting up a new EU account and then pair the robot again.
Surprisingly, the map is still there when i connected into the EU!
Hmm.. why no good? i'm still using it at least 3 times a day.. bought extra pads and hepa filter from AE.my short review : Not good
Works well, no issue..
P.S: CHANGE TO ASIA SERVER, EU server used to be faster, now ASIA server is way faster.
And changing server DOES NOT Erase any data the need to remap. it's like migrating the account.
BUT when you change server, your cleaning records get erased.
Maps and setting still stay, at least for me.
I would say with a 20% Qoo10 coupon, this is quite worth it if can stack with store coupon.
-slow loading
-user interface not good
-if u put obstacles in the middle of the path, it will go haywire.
-if u put obstacles near the dock, it will also go haywire
-u wall, it can go into invisible room
-mopping/sweeping not as clean as roborock.
For e.g
roborock.... 1 sweep with normal suction....no hair strands.
redroad.... 5 x sweep with turbo suction... still got hair strands. lol... not corner!!!
what the use of vacuum robot...when i still need to use handheld vacuum.
If a robovac keeps creating new ghost room, it can be confirmed electronic issue because it’s compass direction is messed up. This is what I noticed from RR and Neabot forum with the latter having most problem.-slow loading
For e.g
nope it is the software side.If a robovac keeps creating new ghost room, it can be confirmed electronic issue because it’s compass direction is messed up. This is what I noticed from RR and Neabot forum with the latter having most problem.
Hi, thank you for your prompt reply. I had done those (except reset the bot) and it is now working again. I guess either the connectors dirty or the slap work.Not sure what this error means but if the pump circuit is open can interpret as no connectivity, then the pump could be faulty. Reboot bot and see if it reset something.
Check the water tank pump if it is rusty wire or disconnected, also the tank connector to the bot connector. Give it a good slap on the pump area to see if some diaphragm is stuck. Else contact technical support.
there is no ghost room.
But after u add the virtual wall, the ghost room will appear
then when ghost room appear, need to reset the map........ sibei troublesome.
For the price point, these flaws are ok for me..... but just the hair strand thingy....
I'm thinking of getting this, can vacuum & mop at high temp at the same time
Anyone using this?
