No.for those using SIMBA, the data connection in SG does it drop often in a day?
nope 4g works mostly but some place the reception is not good .. also in lift 95% wont workfor those using SIMBA, the data connection in SG does it drop often in a day?
besides lift what are some places like?nope 4g works mostly but some place the reception is not good .. also in lift 95% wont work
$10 only just try and usebesides lift what are some places like?
i planning to get the superroam$10 only just try and use
CBD, in MRT, in tunnels?Whole sg is very big you need to be specific on your questions
will also be going to Europe soon, do u happen to know if the connection there is stable? UK/France/Italy/Switz/GermanyCovered under general 4g network coverage which I had mentioned, since your location are general places asked. Super roam is just a roaming package for overseas use
Myrepublic, VIVIFI, redone
i see, btw for simba superroam can use it to turn on hotspot?
check simba website faq i am sure there's alot infoi see, btw for simba superroam can use it to turn on hotspot?
FAQ dont have, no dedicated hotline for supportcheck simba website faq i am sure there's alot info
can go TPG bang table?Recently travelled to Batam, my simba sim could not connect to roaming network, thus no roaming service.
Free roaming service, can't complain much ....can go TPG bang table?
this one is user problem. i used smartfren just fine, from south of sentosa until balerang bridgeRecently travelled to Batam, my simba sim could not connect to roaming network, thus no roaming service.
maybe ur phone no band required? i use poco x3Tried many times, all networks cannot connect manually, including smartfren.
I have no roaming issue in Malayia
