[Software Update] iOS 16.3.1
szeli
Seems like turning off private relay fixed the issue. Have not tried “limit ip tracking” though I found that option now thanks to leong
"limit ip tracking" fixes e embedded social media videos (tiktok, ig, fb etc) not playing on hwz issue.
swathe
After monitoring for a day. Removing limit ip tracking works the best
szeli
hmm. im still facing battery drain issue though. i updated like last tuesday, still drain pretty fast. Sian, should have stayed at 16.2
check e batt stats? my batt in 16.3 same as 16.2..
szeli
U mean the battery health? I also check the daily battery report. I’ll just see again these few days how.
I meant check e batt stats to see what apps are draining
Whizdom
i updated to iOS 16.3.
battery drains like crazyyyyy.
within 10mins of not doing anything drop 10percent
r3f3r3e
yea i realized why batt drop alot is because of the heat. mine also like that. now mine quite stable already but then i feel still abit more battery drainage than IOS 16.2 though
elimmel
Updated to 16.3.1 and now my wifi connection is wonky. full bars but no internet connection. iPad Pro without update no problem
Snoweagle
That's strange, I've no issues with that on my iPhones and iPad Pro.
