S23 accessories discussion
phrozact
Coming from the S21 Ultra, the fingerprint sensor seems to work tons better for me. Using film type screen protectors, the S21 Ultra would have trouble recognising my thumb if it's slightly dry, but haven't had issues on the S23 Ultra.
pau1ine
I want to get a cheap clear case for s23u. Anyone already bought from hp shop?
Thanks!
Cyborg
Thanks!
Clear case available at Blazing Handphone shop in TP.
I did not buy since I already received a cheap armour case from Shopee.
Glariel
Thanks!
you may want to try from those ah beng shop that sells phone accessories to see if they got sell.
i wonder if i show my singtel contract can i claim the free case.
i waiting for rhinoshield to come out, until now still say coming soon.
but its ok since my phone only arrive on 20 March.
jjj9288
Fyi...using spigen tough armor case, applied wsd yesterday, able to fit, left very very little space between case and the screen protector...just share compatibility info for those who want to have same combination...
FuzzyLop
How is the FP detection like for WSD?
jjj9288
So far so good, registered same thumbs x2, able to unlock 99% of the time, but feels like the response slower compare to naked.
This is my experience with my own thumb...May not be same with others...
amazingone
This ESR case looks good, with raised frame around camera lens also acting as kickstand
https://shopee.sg/ESR-Samsung-Galax...lassic-Kickstand-Case-i.139383672.19072041321
trenzterra
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.2dd52e8dn900fn&id=697236971820&_u=d28gi5bbae8b
Sharing this screen protector, very easy to align and apply. Looks a bit soft at first, but once cured with UV, it behaves like the default Samsung screen protector (at least the one that come w Samsung phone last time). When you peel off got the satisfying ripping sound effect. No rubber peel effect. s pen works well, at first I thought still rubbery but I realised it's because the pen tip is soft lol. Only thing is you need to make sure all the sides etc are pasted down properly before you use UV to cure. If not once it hardens, there will be bubble/ cannot stick properly
