Dental clinic in jb
Johnringo
@hwsstx any idea if the sunny dental take bookings for general cleaning/polishing? or any other dental that is good around 2nd link area?
thanks for your help!
kaixin18
Johnringo
FYI
whatsapp the sunny dental in horizon hill area and asked for price of general cleaning/polishing
Got quoted RM120-180
Also - do note that they require you to make an appointment before going down. Still thinking if I should go there so have no real experience with the clinic to share.
tiertime
FYI
Sounds expensive... 🤔
Johnringo
Anyone has experience with Tiew dental at Bukit Indah area? It seems to be just opposite Lotus so much more convenient for me as I usually go via 2nd link
Google reviews looks good but not sure if is real reviews haha
hwsstx
Search this Thread, there are a few about it
Habrosus
That's the popular one over at 2nd Link side. And yup, got to search this thread for reviews.
craze_ho
I'm thinking of dropping by early morning.for first timer will take how long? Weekday should be okay right? Sg polyclinic is so long to get appt..
hwsstx
If you are going to Dental Clinic CH Tee, Taman Sentosa, I usually will be at its shutters about 8.30am.
Shutters open about 5mins to 9am. Present your passport for registration & what consultation you are seeking.
Then you sit till you are called.
If you don't have any serious issues, & you just want a general check up + cleaning & polishing, then you'll likely be called before 9.30am.
Chanrusnet
Has anyone tried dental treatment at SG Dental at Taman Pelangi? I read very good reviews on Google but seems pricey compared to CH Tee (which I read on this forum). I whats app them and was told root canal treatment is RM1,500 and zirconia crown costs RM2,200 each and if it is procelain/metal crown, the cost is RM1,500 each. Hope to hear from anyone who has been to SG Dental.
hwsstx
Go for it, add more choices to this forum.
Start off with cleaning & polishing, & then if comfortable try other consultations.
zeroX26
Much cheaper than Singapore liao. I just did my crowns (metal ones) and its about $850 each. Root canal treatment is about $700 or so? All these r private dental clinic prices lah.
