Circles.Life Discussion Thread
sullycoin
How the circles life review? I was thinking taking up a line. Thanks
It's what you would expect for a M1 line, but not quite as bad as the other MVNOs. Honestly, there is nothing too special about it compared to M1, you're probably better off getting a line direct from M1, which is sometimes cheaper! I picked CL over M1 only because I needed an eSIM line for about 6 months & CL eSIM provision is free, unlike M1.
CPTMiller
Thanks for the info
Reborn
anyone knows how to cancel plan? the option stated in their help faq cannot be found.
lohsenglte
the terminate account button is not there when log in. The other 3 like change number etc. are there. but not the termiante button
Huh I can see it in my account leh?
You might want to do on incognito mode or something, maybe cache is playing with you.
lohsenglte
will check again. maybe they added back the option after sending a support message.
Go through that link using incognito, then press MANAGE ORDERS.
Maybe is your browser or just that the API call to show the terminate account button wasn't activated.
Reborn
good idea. Thanks. Didn't think of that.
