titusilvering
That code is to enable VoLTE for unsupported carriers.
I got other phones using same sim no issues instantly detect and show volte.
Some more those phones are older than the one i just bought which is 2022 model and fresh from factory 2023.
Basically xiaomi is all like that
twosix
so volte turned on with the code already? then why still complain?
lohsenglte
Cheap phones... You get what you paid for?
titusilvering
Because it's dual sim. If after key the code to turn on volte and use 2 local sim the volte will not be gone after reboot phone.
Problem come when use 1 local sim and 1 roaming sim. The moment phone reboot the volte gone again for local sim and need to disable the roaming sim first to dial the code again to make volte appear again then can turn on the roaming sim.
Other brands or older phones no such problem.
So it is really xiaomi problem
twosix
Indeed. China brand really is 烂泥扶不上墙。no wonder samsung still best.
I can imagine why amdk look down china tech because they always cut corners somewhere in their products
how do u know what is good or bad when u dun try other brands? haha.
for most people who use 1 sim card only, xiaomi phone is cheap and good. where to get a sd870 soc phone at $400?
titusilvering
I told you i got other phones.... Omg
crystalnox
Wah this sounds like a software bug only la, relax. Don’t condemn an entire country, China budget phones can be good value for money if you don’t mind looking past some quirks. :LOL:
titusilvering
A simple phone also cannot make good, i cannot expect they able to make highly sophisticated equipment good
anthonygreenisreal
can ask you all if the $10/mth for 100gb plan good or not?
in terms of reception and overall usability?
I using iphone 14.
Biskochoco
I using iphone 14.
Good enough for regular usage and if you don’t travel monthly for - $10/100gb
can apply for secondary line to try out for 2 months 1st before you decide to port over (in case reception not ideal for you in your area or hse 😅) port over from m1 after trying it for 2 months too
otherwise reception n usability- to me it feels like other 3 big telco lol
Read HWZ Forum Rules!
anthonygreenisreal
Thank you for the review. Very helpful
colton0
Not xiaomi problem. My redmi9 bought in 2021 always auto volte. Use common sense instead of smearing china brand phones cause their big share in ccarland won't exist if not for ccar finding good value for money.
titusilvering
I got 9a and 10c. Both need key in code to enable volte. 9a is export set. 10c is local set
