VIVIFI
gapboy
If Singtel/their MVNOs can come out with a 5G SA plan for $18, I’ll jump over instantly. Singtel has far better 5G coverage islandwide making their 5G SA a lot more valuable for those chasing the 5G high.
probably true .. i havent tried Singtel SA but i believe will be better than the collab btw M1 and Starhub under MyR
lordfa9
I'm using vivifi lite right now and thinking of switching to the family plan and bringing my family members onboard
How is the family plan? Any hidden things i need to know?
Rxgn
Family plan is good
180gb
nothing to hide
Everything is the same, im using it since vivifi started this plan day 1
Krabs.
delivery and port-in after 50+ hours , no issue :o (y)
the promo free 30gb is by month ... lets say now 18th of the month u only get remainder 10-11 days to enjoy it + the pro rated base GB ....
if u activate at near the end of the month u don't really get to enjoy the "free" , more accurately to say free 5.x month not exactly 6 month cycle
not complaining though .... since the plans are affordable (y)
lordfa9
Couldnt get a straight answer out of Vivifi support so hoping someone can share if they overcame a similar problem
My family all the ownership of the numbers (all M1) is currently owned by my dad
We (the whole family) were thinking of getting a vivify share plan
I have my own vivifi lite line as 2nd number
Current plan is to convert my vivifi lite line to vivifi share then port all my family's numbers over
Does the ownership of the numbers need to be transferred before we do this?
  • If no, this means my dad is still the owner of all the sub-numbers right? From an administrative view
  • If yes, does this mean the ownership of the numbers need to be transferred to each individual family member? Or all the numbers ownership transfer to me?
shawnng
Yes your dad will still be the owner of all the sub number.
All sub number / individual family number will need to be under his IC.
unknownz
based on understanding,
1. when doing a port in of all your family's numbers from m1 to vivifi, the request has to be submitted using your dad's info (since currently owned by him)
2. once all your family's numbers gets ported to your vivifi share plan, ownership of all the numbers will be under you (since the share plan is under you)
Arandalo
See this post
https://forums.hardwarezone.com.sg/threads/vivifi.6299241/post-139905038
Basically Vivifi supports transfer of ownership for number porting.
Can only do after new Vivifi line/plan is activated, not at the point of sign up.
Detailed steps in the FAQ page.
No need to transfer ownership of numbers before porting to Vivifi. M1 will charge you a significant sum for doing it (since multiple lines) and you’ll be wasting your money. Keep it as under your dad ownership.
Once you port all the numbers over to Vivifi, you will be the owner of all the numbers (which was previously under your dad ownership).
wishys
Just signed up for vivifi recently. I realised under profile tab, my details section, my given name and family name details were swapped. I remembered these fields were populated via Singpass, not keyed manually.
Anyone encounter the same thing? Not sure if there will be any name verification issue if I were to port out in the future.
crystalnox
Yes mine is the wrong way around too.
shawniiex
ported to Vivifi from Zym for my sister couple weeks ago.
feedback is constantly getting full bar reception, but takes forever to load.
sounds like M1 all over again.
will be porting out once 2 billing cycle is up.
lohsenglte
ZYM don't have the same issue?
386863
CMLINK don't have this problem.
Working perfectly...
Aiya, I just ported out to Vivifi haha. i have 1 number with VV and the other with CMLink. Thanks for sharing d info anyway! Gd to know. Maybe aft 2mths i'll port d other back to CMLInk.
Rxgn
What you experienced, might not be the same to others.
If work, stay
If dont work, change telco
So far vivifi have been best to me.
