Google Pixel 7 series
What upgrade would you most like to see on the Pixel 7 series?
  • Total voters
    140
joesph
Does anybody here own both Pixel 6a & Pixel 7 ?
I would like to see a comparison of main camera pictures at max zoom of landscapes.
Thanks !
Yes, I know there's a Pixel 7 Pro ( and I should get it if I want a tele lens blah blah blah )
But that's not what I want to know.
I
of course clearer on 7 pro, 30× vs like 10×?
Read HWZ Forum Rules!
blurboiboi80
I ported my number over to singtel and am still getting "no service" occasionally... Sadded... Very disappointed... Guess I will need to get another phone to move everything over before getting this hp fixed.. :(
asdyui31
Hi all, I am considering switching my phone to pixel 7 pro but have some concern regarding it's battery life, those using it now can I know how is the battery?
algerr
U are on SIM-only right? port over to other providers to try out - e.g Starhub, Giga....
It may not be phone issue.
Will be better for you to switch to Pixel 7 Pro if u are more into the vanilla android experience, the camera... basically that's it.
Otherwise, wait for Pixel 8 pro
Battery life is disappointing and very prone to heating up - be it playing game and stream youtube.
Thinking on bright side, it can be a handy heat pad in the pocket to warm the balls during cold days... =P
vivalarave
how hardcore of a user you are?
Do you need 7 hours of SOT or just lightly text and message.
The battery is good enough for 1 day usage if you are not glued to the screen non stop.
Loser
【淘宝】https://m.tb.cn/h.Un47aKf?tk=2IApdSgGYjp CZ0001 「谷歌pixel7pro钢化膜谷歌pixel7pro手机膜uv全胶钢化膜曲面全屏覆盖抗蓝光护眼防指纹7por保护贴膜适用于」
点击链接直接打开 或者 淘宝搜索直接打
4 for 20 bucks. Really good value
Can confirm this is good.(y)
One nitpick is the sides if don't cure long enough will have some white edges. Dunno is if glue not enough or not enough UV light.
plsdunbiteme
Just want to share that even though the camera on Pixel 7 Pro is v good, it does tend to miss crucial shots, esp when you take few photos in quick succession.
The shutter button will be greyed out and refuse to snap pics until the earlier pics have finished processing in the background. I notice this happens a lot when taking photos in difficult and low light environment, probably the processor have to process more, and cannot keep up with the load.
mindgamey
Take a pen knife, and touch some excess glue and feed it at the edge, the white empty edge will be gone.
tictactor
Anyone fiddling with opencamera? Was wondering if should make the switch to be able to change shutter speed/ISO
