USD Fixed Deposits
churnmaster
I intend to...
I actually trf the money (low 5 digits) to Ibkr, thinking I can buy t bill from ibrk. So I converted to usd already. Turns our their minimum quantity is like 350k$.... What a waste of effort.
So im trying to withdraw to dbs usd fd, but ibkr is blocking me now Becos it's a new account. Deposit and withdraw without transaction, they think it's suspicious....
You are wrong. You are probably guessing based on the bid / ask quantities in the quotes.
serverxeon
Just keep in USD FD lo. Cheapest way to convert to SGD is transfer to IBKR, convert there, and transfer back DBS in SGD. The turn around takes up to 1mth I think.
Take note IBKR only one free withdrawal per mth
Yep. Ibkr exchange is best.
But if you open a brand new account just to do this.... I think they'll probe a bit whether you are using them to launder money hahaha
reddevil0728
dbs usd offers 1 month fd, auto renewal. 4.04% pa for below 100k.
I'm just using multiplier account to change from sgd to usd, lose on conversion. Do you know if there is a cheaper method? :)
you are converting SGD into USD just to get higher interest?
and you hope to convert back to SGD in future and make a profit?
might as well leave it in IBKR and buy T-bill
greythorne
What you mean by “The turn around takes up to 1mnth”?
serverxeon
Yes. I might be wrong.
I did indeed estimate using bid ask volumes.
However I can't tell what's the minimum to transact. Only that it keep telling me error, pls up my volume. My volume too small, they will not send my order to NBBO.
reddevil0728
what's the quantity you indicate?
you know each quantity is $1,000 right?
So if you indicate 20 it will be $20,000.
and definitely no where near 350k. that's mad.
and surprise you really go change 350k thinking that need that much to invest.
dgeralds
Hi All. I recently excited 100% from US stock market. Funds in USD (about SGD 236K) in sitting in IBKR. Im waiting for the next opportunity to go in......but not sure when that opening will come about. Should i convert back to SGD and continue keeping in USD while waiting? Im worried USD exchange rate drop..
serverxeon
Yes I'm aware 1 quantity is 1k.
I indicated correctly the quantity (value /1000)
I did not change 350k. That's why I decided to pull out my funds from IBKR.
If you refer to this guy, he couldn't buy with 50k bid too.
reddevil0728
if you convert back to SGD are you already losing on exchange rate?
and if lets say there is going to be a capitulation, chances are USD may shoot up again, so you change it back to USD at a higher rate?
You need to have a plan for investment. not so simple and straight forward one.
oh apologies. misunderstood about the 350k.
Did you enable the permission to purchase?
serverxeon
Yes I did.
No problem sending the transaction, except Ibkr gave error to "make my bid more aggressive"
gobin74
Hi for usd fixed deposits which fi is giving the best rate pl currently in sg pl
Thnx
gobin74
Note that usd fd for 12 months. Is still. available at > 4%....ln case you. Still. Have usd maturing
Thanks
shin89
Was doing USD FD at DBS before 50bps rate cut, 2months was 4.75% pa, i think now 2 months is 4.6%~
