[Official] Playstation 5
Recce5
lordlad0
Do you have 3D Blu-ray movies? If so, maybe can help to test out whether can view 3D content.
Also, there are some PS4 games that are 3D compatible, e.g. Trine series, Sniper Elite 3 & 4, Super Stardust HD, etc.
Thanks.
reviewers already tested that....not compatible with 3D Movies....the PS5 media player will need to be updated.
stone83
Managed to fill around 4TB of PS4 games on the WD Black 5TB USB drive.
Not sure is it the size over 4TB or having too many installed games, when I go to the PS5's system storage details page it sometimes show the USB extended storage as no drive attached, even though I can see the games in my installed library and run them without problems.
The 5TB external drive barely holds all my PS4 digital games, as I did not install those multiplayer online games and non-single player games from PS+ cause I mostly don't play them. Plus I still have the physical games which need installing into the drive if I wanted to play them. My internal 2TB SSD had around 1TB free.
I think the best storage combo right now is a 4TB M.2 SSD plus a 5TB USB drive, but the former is still very expensive.
intending to get a M2.SSG 2TB, which brand should i go for. Sandisk or Samsung?
need some advice pls.
lordlad0
PSVR2 headset in the house!!!!
Guest starring PSVR1 and Oculus Quest 2..
Recce5
I highly doubt Sony will update 3D on PS5 as it is abandoned by all the TV manufacturer.
Sad situation really, the 3D support should be straightforward to implement on VR headsets.
Oh well, can still use my PS4 with PSVR, just need to set it up somewhere in the bedroom, or maybe one corner in the living room.
Recce5
How often do you clean your Ps5? Weekly, monthly, every 3 months, none at all?
Do you need to?
I've never cleaned any of my consoles from the NES, Sega Master System, SNES, Megadrive, Saturn to the PS1/2/3/4. And all my PCs and notebooks as well right from the PC XT Turbo in the 80s till now. None of them had any overheating problems, dust or no dust. Also I don't turn on aircon at home so all of the above systems running at the typical room temperature in SG.
That being said, I'm sure others may have differing experiences than me when it comes to dust. :)
Unic0rn
stone83
Didn’t we share it previously? Bought it from Amazon US. I think damage was $200 usd.
preferred one better for the console.
theres 2 types. -
Works with Playstation 5, Gen4 PCIe, M.2 2280 ,$246​
or​
for PS5 Consoles Solid State Drive with Heatsink ,$301​
