Yongkit
- Oct 9, 2015
I do agreed air cooler sometime seems simple, but to certain extent could be the most tedious part and longer time to assemble compared to other component which is plug and play.Actually the CPU core temps runs high when I run a certain game.
I had open a thread in HWC.
Really regret using the stock cooler. Double job. Have to remove the original black socket clips and then put in the stock cooler which imho not as easy as it looks. It looks easy on those youtube videos, but in reality not easy as need to screw down 4 screws evenly. Took me almost 45 mins.
Guess after all these years, AMD still give out lousy coolers. Last time AM2+ /AM3 time, I never use their stock cooler. Prefer cooler master hyper 101 or deepcool replica.
your cpu temp is still within the acceptable range not over 90c even using igpu for gaming, which should be much better than many other stock cooler, it might not be the best but also not the worst.
sometimes if the cooler does not sit equally balance could also affect the temperature of the cpu, but i doubt it will be the case since your temperature is within my opinion acceptable performance.
the only information missing was the cpu fan rpm from your current screenshot I am not sure how fast does it run and how noisy you are experience currently. Normally i will monitor my system stat with HWiNFO instead of this HWmonitor.
nevertheless over time it is still good to invest in a after market air cooler since there are many option available now in the market.
truly there is nothing alarming based on current indicator.
I will take a look on your other thread in hwc.
