DCS Ultimate Platinum Card
hclee01
DCS Card Centre (Former Diners Club Card Centre) has just launched the DCS Ultimate Platinum Card. Interestingly, the card has a China UnionPay logo which seems to suggest that it can be used at China UnionPay Cards Accepting merchants, which increase the ability to use this card as compared to DCS network which may be limited.
Enjoy up to 2% Unlimited Cashback# on all purchases on the DCS Ultimate Platinum Card, with no minimum spend and no cap on the cashback earned.
#2% Unlimited Cashback is valid till 30 June 2023 (the “Promotion Period”). Upon expiry of the Promotion Period, every Card Transaction is eligible for a 2% cashback (capped at S$200 per calendar month).
https://cards.dcscc.com/ultimate
CrashWire
Might as well just apply for this:
https://www.uob.com.sg/personal/cards/credit-cards/rebates-cards/uob-unionpay-platinum-card.page
dhwang_best
applied almost two weeks ago, still processing...
sglandscape
For those who have use case this would be good, otherwise its rather difficult to spend on the card (not widely accepted online or in stores)
susesucks
I got mine about two weeks ago. The online transaction works, but the card itself is always declined. I've tried using this card at NTUC, Watson's and 7-Eleven for the past two weeks, all transactions failed. Made a call three times to the customer services, too (note that they are only working during office hours and very hard to get).
Was told that:
1. Paywave doesn't work until further notice.
2. Must use chips, but mine is declined regardless I entered the PIN or not.
3. Was told by the customer services to skip the PIN, but there's no such button on the payment terminal (there are only green, yellow and red buttons). When I pressed the green button without entering the PIN, it failed. When I entered the PIN, it also failed.
4. Customer services also can't do anything as the declined transactions aren't reflected on their end.
It feels like doing a UAT test for DCS. Considering to cancel the card now as it doesn't work and no solution provided.
susesucks
Was told that:
DCS finally reached out, saying that the card isn't usable at the moment due to problem with Nets. Will be fixed after 8 March. 😅
susesucks
Thanks for the update! How long is the processing time for time of application till it is approved?
Quite fast. I seem to recall that the process was less than two weeks. The problem is, up until now, the physical card is still not working even though they said it should be fixed by Nets today.
wuming79
Any one has issue cancelling the card? Their call center is useless. You can't talk to any agent. Left msg to call back no one calls. Write email to them no one replies. It has been 2 weeks.
adrwong
What a joke … I tried calling them for the pass few days but no one answer as well. Also wana cancel their useless card
wuming79
OK, they finally replied my email and acknowledged my cancellation without question. Hope they will reply you soon.
sglandscape
What time did you try calling? Literally did it a few days ago and my call was picked up almost instantly after going through the menu.
duststorm
I called the hotline last sat to cancel card. And today i received email confirmation that the card is cancelled
Travis_Touchdown
i'm more interested in the dcs cashback card... minimum spending $400 with 5% cashback... cap at $50 cashback... anyone using this card?? is it widely acceptable in sg?? :s12::frown:
vaart88
Was told that:
Hi which online merchants did u use and manage to transact. I tried many online merchants but declined thanks
