FatalethaL
- Dec 17, 2008
Hi guys,
It has been many years i last visited this sub forum. I do see some familiar guys still hanging around and helping this community. Great to see you guys are active and hanging around!
BTW, I am hoping to get some advice from you guys and hopefully with your help and advice, you can point me towards the right direction (i have been out of this DIY computer scene for quite some time). Presently, my PC is showing signs of aging and weird symptoms. Behind the scenes for past 2 weeks or so, many friends are helping to troubleshoot my PC problem and we realised we are going in circles and still unable to nail down the problem. Time is money and I use this PC for work and personal use.
Hence, I am thinking to do a "small upgrade" for my PC for a fresh start.
Currently, my specs are as follows:
Now, I am thinking to upgrade by recycling some parts:
About the new parts, I am not entirely sure if they are a "good fit" in the system. My goal is to keep the system running for the next 3 years while not spending too much (keeping costs low) and I could play games like the upcoming Diablo 4 and what not, comfortably. Hence, would like to hear opinions from you guys regarding my choice of parts, namely Mobo, ram, and SSD.
Will it be a good fit? Is/are there any concerns? Are there other options up for consideration? Finally, are there any huge differences (in terms of feature and performance) between ASrock B550m/ac and the ASUS TUF Gaming B550m plus wifi ii?
Cheers, and hope I (and some others who are reading this) can get some clarity out from this adventure.
*Side note: I might upgrade to 5800X3D if the price is right aka lelong.
- AMD 5600 CPU (previously it was AMD 1700)
- ASUS ROG Crosshair VI Extreme
- Samsung 960 Pro 512GB M.2
- Corsair 3466MHZ 16GB kit (8GB x2)
- Zotac 1080Ti
- Seasonic Prime Platinum 850W
- Thermaltake P3 Open Chassis
- AMD 5600 CPU
- ASrock B550m/ac or ASUS TUF Gaming B550m plus wifi ii - Kindly advise this new part
- WD Black SN850X 1TB M.2 - Kindly advise this new part
- GSkill 3600MHz 32GB kit (16GB x2) - Kindly advise this new part
- Zotac 3080Ti (my previous 1080Ti might be sold off cheap cheap)
- Open Benchtable V2
