Cyborg
Okay! Got it!
I will just top up and keep a $10 in the Wallet for pay-per-use data and calls usages at the initial stage. Afterall, the Wallet can be topped up anytime even while in overseas via wiFi /hotspot from other mobile too! 😙
Thank you so much. :)
Glad to share related and helpful info. (y) :)
mikki23
is simba coverage really as bad as some of the users commented? 1 bar in their own house?
im currently on signtel sim only, and the new plan is $30 (first 6 months) and $45 thereafter. the coverage and speed is good but really bo hua to pay double the price.
was about to pull the trigger for gomo $25 for 100g (since they are on Sintel's network) then my colleague told me of this $10 for 100g on 4g. I dont mind 4g speed, but i cant deal with low to poor reception.
kaisoz
Go get the $1 voucher first, then click the link to the seller. at the checkout page, enter ur phone # to top up Message area. Pay and wait for the seller to top up. SIMBA will sms to confirm the top up.
Kamsia for the tips and shopee link!
crystalnox
You have to try to know, nobody frequents the same locations as you do.
gapboy
we wont know where your house is .. cannot comment on the signal at your place .. trying is the only answer .. port out again if you dont like simba service.
frizee
How does this top-up work ah?
Those top up ones be careful, for example as long as your balance falls below $10, it cannot be used for next renewal... I kenna once lol... :D
frizee
Pls elaborate. No head no tail leh.
Example u kenna some random overseas sms or sth, then become $9.50, the next renewal they require a whole $10, so they'll ask you to pay credit or something loh...
Cuz initially i thought since my balance is $9+, i can let them deduct the $9+ from my wallet (for my next renewal), and the balance few cents will auto deduct from credit card but no :(
Ended up using as pay-per-use once your free roaming runs out ;)
barnabaskoh
My Shopee under voucher dont have the $1.. may i know where to find it ah
mikki23
ok i just applied for it. i saw that it says my plan with singtel will auto cancel. is that correct?
Do i need to do anything from my end with Singtel? Im on post paid plan, no more contract
gapboy
first time port out ? no need to do anything .. port out and in to new telco is auto after midnight usually alot info in the faq usually
mikki23
pretty much first time.. been with singtel since i first got my mobile phone about 20 years ago. Thanks!
twosix
Err ok. Cannot top up the acct? Feedback to Simba why cannot. Maybe a bug on their side?
