Phen8210
 - Jul 29, 2011
Watched many ssd data recovery videos on youtube. Some cases were a single tiny capacitor resistor faulty. Many cases of samsung nvme ssd with blown fuse, pmic. Maybe unstable power supply in laptop dc power brick.
I am pretty sure that the cheap ones are caused by failing controllers because the majority have early signs of intermittent detection. The controller is responsible for managing the communication between the SSD and the computer, and if it is not functioning properly, the SSD may not be detected consistently or at all.
I usually contact customers to see if they have experienced intermittent boot issues before the SSD completely fails. Sometimes, they report that the system crashed and they couldn't boot into Windows because the SSD was not detected. They had to wait for about 10 minutes before trying again for the SSD to be successfully detected.
However, it's important to note that the environment in which an SSD operates can also be a significant factor in any part failures. For instance, when operating on a desktop or server, there is usually better airflow, and the system is less likely to run at temperatures as high as 90°C. These factors can contribute to reducing the likelihood of a part failure in an SSD. Therefore, YMMV.
 Can trust one?
