Gaming Keyboard and Controller Latency
Yongkit
Is this considered good or bad? It says average is 2.07ms.
Am using PS5 DualSense controller with DS4Windows running at Bluetooth 1000Hz polling rate.
wow fast and close to 500Hz polling rate (y)
Phen8210
good, dualsense has the best wireless, its unbeatable
maybe u change to 500 see the results better or worse, because it cannot run really at 1000
Yongkit
After an hour play for mw2 i can confirmed this keyboard is so much better than my strix ROG Scope I can dodge bullet so much faster and turn back to counter shoot which my ROG Scope keyboard like dragging the leg and cannot run once hit by first bullets.
Phen8210
yeah cos u got hit by more bullets due to the delay and it slow you down more :spin:
Yongkit
just try the keyboard latency test for fun and manage to get 1ms 1000Hz 🤣
:cool:Take these calculations with a grain of salt:cool:
tsteo77
So is this cosair mini rgb keyboard
So does this cosair mini rgb gaming keyboard meet your gaming need ? :)
How about your search/recommendation/comment for best performance gamepad ?
I'm currently using logictech f310 and sony dualshock 3 gamepad and i only use gamepad to play on pc.
Keyboard has too many buttons, don't have good memory.
Yongkit
Yes the keyboard meet meet my "gaming" requirements :)
For gamepad I still recommend for the 8bitdo ultimate for price to performance
8Bitdo Ultimate Wired Controller for Xbox Series X, Xbox Series S, Xbox One, Windows 10 & Windows 11 - Officially Licensed (Black) https://amzn.asia/d/eDqHnyz
Yongkit
become more sweaty :O
Last night was crazy matchmaking few games I play keep fighting with player 200++ level while my casual novice skills only level 10.
I don't play much multiplayer previously because my old keyboard just can't keep up last time.
Phen8210
try play gameboy, only got a & b + d-pad
Phen8210
Hopefully this informative for your consideration
While it has Hall Effect joysticks n decent latency with 2.4GHz.
The D-Pad has accuracy problems, so I'm skipping.
https://shmups.system11.org/viewtopic.php?f=6&t=71082
Same report here
My 8bitdo Pro 2 also has d-pad accuracy problems.
For games that use D-PAD as the main control, reviewers need to test for ghosting and also diagonals. But many of them just press the button on the d-pad a few times n claim "feel good" "very good d-pad" :spin:.
Good my ass :LOL::LOL:
ronnie_gogs
There is travel time which is 2 in case of a mechanical switch, actuation force needed to actuate a switch which is mid way and then bottom out the switch. Since we talking in milliseconds here. Wouldn't a better test be to hook a oscilloscope or logic analyzer to the switch and the USB connector in the end. How long before a switch is pressed and actuated to USB connector at the end getting a signal.
The delay due to keyboard PCB processing the signal should be the main concern.
Yongkit
https://www.rtings.com/discussions/Ci5CpCatqyovgoeC/key-release-latency
I think this is what they do for now.
elmariachi
You are spot on with this. With my wooting 60he, it wasn't the actuation point that made it feel faster. It is the fact that the reset point is the moment you lift your finger off the key. They call it rapid trigger. So you don't need it to actually go back to the reset point like normal switches making the keyboard feel faster. I myself do not set my actuation point too low as I tend to rest my fingers on the main keys during gaming and it's very easy to actuate them. What's most helpful is the reset point when you lift your finger off and it resets immediately without needing a certain travel point to reset.
