Google Pixel Watch
azarel
Hmm currently am in Japan... Was wondering if it's worth getting the Google pixel watch while I'm there..
halocast
does anyone know how do we get RMA replacement? Battery charging issue.
My watch purchased from Amazon JP shipped direct to SG. Amazon said to contact Google. Google said the Pixel watch not released in Singapore market
Go to sg distro for pixel? :o
limmk
March 2023 Google Pixel Watch update is here with Fall Detection and loads of other improvements
After this update, the Pixel Watch is now on the March 5, 2023 security patch level. RWDA.230114.008.R1 is the new build number with a RWDA.230114.008.J2 variant for watches in Japan and Taiwan. Compared to the last three updates, it’s no longer RWD9.220429.x.
What’s Included​
  • Watch Faces – Digital Clock is now available with button press when the device is powered down. The time will now appear upon crown push, alongside the red low battery indicator.
  • Display – In addition to enabling AOD in the settings on your watch or companion app, you can now turn AOD on by rotating the haptic crown, and the screen activates in AOD off and brightens display in ambient mode.
  • Touch – Optimizations have been added to improve sensitivity of touch screen behavior.
    Settings – Battery saver enable/disable single tap support in QSS has been fully enabled in this release.
  • Alarms – In the coming weeks, a fix will be rolled out via PlayStore to update the Clock app that addresses some alarms which have been having a delayed or false start. Ensure Auto-update apps is selected in Play Store > Settings on your watch and you will get this update once it’s available when your watch is on charger and connected to Wi-Fi.
joesph
but can ask them to help service?
end January I was @ CTDI they say don't do
Read HWZ Forum Rules!
osmond19
After updating to March update, I seems to be able to locate the fall detection even from the Personal Safety app on the watch... anyone found yours?
osmond19
Not available in SG (unsupported region), fall detection will be unavailable. same as call screening, hold for me ... haiz :rolleyes:
Love, hate, love, hate ...
yes many many features dun hv.... pixel 7 pro even the vpn also dun hv. then pixel watch the Fitbit ECG also not supported as well. even citibank cc also not working on pixel watch gpay.
limmk
I quickly settled on a set of screen protectors from a brand called “Flokinice.” The three-pack uses auto-dispersion liquid glue to adhere the screen protector to the Pixel Watch, with curved glass to match the watch itself. This is an installation technique identical to and popularized by Whitestone Dome. It’s a process that works great for curved displays, and also has the welcome side effect of masking scratches.
