Zero1 Mobile discussion thread
lohsenglte
For zero1 roaming (without subscribing any roaming packs), can it be disabled? Just want to be able to disable to be safe when not needed. And enable only when need to receive SMS OTP when overseas. Thanks.
I don’t think it’s wise to do so.
Configurations might be pushed to your SIM card for enabling/disabling roaming when you’re on home network, so if you decide to screw around, you might lose service entirely if the sim profile gets corrupted.
it’ll be a messy and expensive process if that happens.
Kitaro9202
When you are in Singapore, there is nothing to do, by default data roaming is disabled on your phone.
When you go overseas, there is nothing to do as well if you’re not using data overseas. By default Zero1 supports pay as your roam (when you are overseas) for outgoing SMS, incoming calls, outgoing calls. Incoming SMS is free (so you can receive all your SMS OTP).
There is no Pay As You Roam for data. If you try and use data overseas (even if data roaming is turned on on your phone) you cannot do it unless you subscribe to their International Roaming Data Packs. Hence, you won’t be charged anything for data for any accidental usage since no data will load.
Pay As You Roam service (for calls and SMS but not data) is provided free of charge. If you don’t anyhow answer calls, make calls, or send SMS when you are overseas you won’t be charged anything.
Now if you want to use (Zero1) data when you are overseas, you need to subscribe their International Roaming Data Packs. Then enable data roaming on your phone. There is no roaming pack for calls and SMS, it charges based on the Pay As You Roam rates.
I suggest you read the Zero1 FAQ page especially on the following sections.
https://support.zero1.sg/kb/c30/roaming-call-and-sms.aspxhttps://support.zero1.sg/kb/c32/roaming-data-plans.aspx
To me personally I think Zero1 is already almost a full fledged telco as it supports Pay As You Roam and this service is provided for free, which some MVNOs (like GOMO) don’t even have. This is important when you need to make an emergency call (for emergency services) or receive calls when you are overseas, you can do it.
Also I don’t subscribe to their International Roaming Data Packs when I want to use data when I’m overseas as the Zero1 rates are not really cheap. Instead I will just buy an eSIM overseas data plan from online (Qoo10/Shopee/Lazada) and activate it just before leaving Singapore.
Imo I feel they quite good have autoroaming and ppl can call you incase of emergency. I know ppl will say whatapp cannot meh?what is like call from hosptial etc u think if they will whatapp call u meh.
That the reason I choose zero 1 compare to other telecom lor
dgeralds
My zero1 app not work now 16 mar, 12.35pm. uninstalled and reinstalled. Still unable to laugh the app.
Please update here if working for you. Thank you.
Synnexo
Is there any way to disable the idd overseas call function for zero1?
If you are using Android, in Calling app (Phone) settings, there should be an option for Call Barring. There you can activate to bar IDD / International calls.
iPhone using codes
Activate IDD barring >> *331*1234# Call
Deactivate IDD barring >> #331*1234# Call
Note: 1234 is default PIN for SingTel infrastructure (I'm using ZYM mobile line) | 0000 is generally for M1 infrastructure.
Don't blame me if the PIN doesn't work.
mosmos
High Honorary Member
Did you check your zero1 app? There's a page to press unsubscribe idd
But not sure if you want this idd service again, need to pay registration fee
Arandalo
I think the 'Unsubscribe' button is disabled.
Kitaro9202
Was at d resort yesterday at downtown east.
Signal quite bad only 2 bar and i having 3.5g connection nia
Arandalo
new promo $15 for 100gb 1 year.
Subscribe to 50u Plan and use promo code Z1P230350 at Check Out
to enjoy 100GB for $15/month for 12 months
https://zero.zero1.sg/promotions/ultra-data-boost-zero1-50u-100gb-mobile-plan/
Arandalo
looks attractive for $15 saw this promo on instagram too , hows z1 compare to gomo / vivifi service and network nowadays ?
I only have Zero1 at the moment so can’t compare to others. Was on GOMO previously until July 2022 when I ported over. Back then I feel both are similar network, both have quite significant throttling at very congested areas. If not so congested then the network is pretty good so far in my own experience.
gapboy
i used gomo 5g before i find it i was still decent then ... and decide to use vivifi 4g cause it is cheaper =) z1 ... not sure cause i had bad experience with them when they just launched g .. i dont find much issue using vivifi probably non or less throttling as you mentioned
