CPU no Light on
harky
Does that mean my PSU die?
Last night still can use one.
I using
FSP AURUM 92+ PT-650M MODULAR
Can I get the 750 one? All size is it same?
wongminmin
could be mobo or psu. u smell/see your psu...... got any burnt etc?
fan got turn, or totally dead?
yeah, but best to use back 650watts.... save electricity....
harky
Totally dead...
No burnt smell also..
So I had no idea which part die haha.
Will it be under power? Haha.
Yongkit
Try flip the PSU on off button for 5 times see if it will switch on?
wongminmin
Totally dead...
ok check for loose wiring, and if possible, change another power cable.
if u upgrade ur build recently or planning to upgrade, won't be under power?
underpower....is the pc will hang or bsod..... u encounter these?
if totally dead..... and the case fans are connected directly to psu..... most likely is psu.
ur current pc only draw like 650 watts x 89% = below 578.5 watts
harky
Oh.. Never upgrade before..
Been using for good 9 year..
Yongkit
When I off using the bottom got electric sound..
Try still cannot. No light
In this case high probability is PSU died, can send for rma.
Recently my platinum PSU also have similar issue but still able to switch on after 5 flips but then cannot hold longer than 5 hours will auto shutdown and send for rma confirm is psu.
NightRaven49
can try paperclip test. if psu fan spin means psu probably still ok and ur mb is the culprit (assuming that really nothing happens, not even fan spin).
tsteo77
Totally dead...
Totally dead most likely the cause of spoiled psu especially if it old. Since you did not mention age of psu.
A 650w psu is the largest logical size psu for typical home use. 1/2 to 3/4 load of the psu is the best. Try not not built a power hungry pc for home use. Our electronics/electrical products can actually run with insufficient power supply. Lastly try to get those good and reliable brand.
harky
Haha..since I going to get new one..
I try to get the best load one.
Soon other part will slowly die and need to do upgrade. Just worry buy too low.. Cannot support future upgrade haha.
harky
Warranty no more la. Buy new one..
Saw one got 10year warranty one.
harky
You got any brand good?
I was looking at
NZXT C650 80PLUS Gold 650WFull Modular PSU (10 YEARS WARRANTY BY TECH DYNAMIC PTE LTD)
MSI MPG A650GF 650 80+ Gold Certified ATX PSU
