samsung pay
cstoe83
Finally found the problem, end up is the my m1 nfc sim card causing the issue.
Now samsung pay on transport work without problem after turning off nfc from the sim card.
username03
Not sure if this has been asked before but does Samsung pay rewards points increase in tandem with the transaction amount ?
Read HWZ Forum Rules!
It doesn't increase with amount but increase with number of transactions you do.
$0.10 or $1 gives you the same points depending on your tier.
If you have a car, some mscp car wash jet can use paywave. So sometimes I take multiple buckets of $0.20 water 😂
joesph
