Phen8210
- Jul 29, 2011
If don't want to change the HSF and casing, I will
improve the airflow around the casing, esp if pc under table. install stronger fans in the casing and the main HSF. Do check the orientation too. I prefer more air in than out remount and repaste the main HSF. If the HSF is screw on, do not screw one side fully in one shot. Gradually screw both sides in.
Nothing will change because TS is using NZXT 500. Go look at the case you will understand
