POCO X4 series
barnabaskoh
Hi I am using a simba with x4 pro 5g at jb but unable to make outgoing calls. I change the simcard to another two phones it work. So issue sls be with my x4 pro 5g. When making outgoing calls at jb it keep saying I activated call barring.. I just bought his phone and didn't meddle with the settings.. Any advice can give me to help me? Thank you
bbcccc
*#*#86583#*#*
shows volte disable jiu can use tpg le
barnabaskoh
Already tried. It doesn't work. And the calls don't work because the call barring is on for x4 pro 5g.
Shutterbox
simba sim cards alrady on 5g?
So far so good with this Poco X4 GT phone. I hope to use it for another year.
MTK Dimensity 8100 CPU is still one of the best mid-range CPU from MTK (some say slightly better than Dimensity 8200). No fight for SD7 Gen 2 but those phones are on the high side.
Still using this phone as the main phone now.
Just upgraded to Xiaomi HyperOS today.
I will probably continue using this phone for a bit longer. Let's see how long Xiaomi will support it. As of now, Poco X3/M3 family has been EOLed. Probbaly soon it will be the turn of X4/M4 family. But it is possible that Poco X4 GT may get slightly longer than the other Poco X4 models.
Reference: EOL list for Poco phones
https://trust.mi.com/misrc/updates/phone
POCO F1
POCO PHONE F1
POCO X2
POCO F2 Pro (Global)
POCO M2 Pro (IN)
POCO X3 (IN)
POCO X3 NFC (RU)
POCO X3 NFC (ID)
POCO X3 NFC (TR)
POCO M3 (TW)
POCO M3 (RU)
POCO M3 (TR)
POCO M3 (ID)
POCO X3 Pro (TW)
POCO X3 Pro (IN)
Last Update Date: 2024-05-27
FuNKySoULyBrO
I also have Poco X4 GT and was notified to update to HyperOS. Is it stable? Searched from google mentioned some apps didn't work after HyperOS update, so I kinda hold off this update for now.
No differences for my simple usages. All apps are working, even the side-loaded apps like Huawei Health (for my Huawei band).
What are the apps of concerns for you? You may want to list and I will see if I am using the app or not.
carboy00
updated my dad's X4 GT to HyperOS, so far no major problems to speak of, I was surprised X4 GT is still as smooth after the update, F4 after HyperOS update can be laggy sometimes.
Read HWZ Forum Rules!
Still using the Poco X4 GT 8GB/256GB version as the main phone. It just got the Xiaomi HyperOS 1.0.8.0 update with Dec 2024 security updates.
I bought the Poco X6 Pro 12GB/512GB in the end of 2024 at S$333.12 as the replacement. Just lazy to migrate all the data over to the new phone.
Updated to HyperOS 2.0.1.0.
Still using this phone as the main phone now that my wife took the Poco X6 Pro 12GB/512GB version as her secondary phone because of screen recorder function (her main phone is iPhone 14 512GB version).
Waiting for the price of Poco X7 Pro 12GB/512GB to drop to upgrade.
nothopingtogether
Is there new model out soon? That x7p will drop
froztheart
Updated to Xiaomi HyperOS 2.0.2. Maybe this will be near to the last release of FW updates for Poco X4 GT.
BTW, the higher end Poco F4 GT has been EOLed by Xiaomi.
Xiaomi EOL list:
Poco F4 GT has been EOLed.
POCO M4 Pro 5G (IN)​
POCO M4 Pro 5G (TR)​
POCO F4 GT (Global)​
Happy that X4 GT is still getting support and updates till now.
Sad that it's likely the end of the road for POCO products released in 2022.
